4.0 SOHC Oil contents
I have the SOHC engine in a '98 Explorer with 44K miles. Oil change intervals have never exceeded 4k miles. There has always been small white plastic particles show up in the bottom of the oil drain pan with each oil change. The folks who do my oil anaylisis can not identify the white flakes. Oil anaylisis does indicate a high steel content in the oil. Ford does not know nor will they talk about what the white flakes might be. The recall that addressed timing chain tensioners was done on the vehicle at about 30k miles. The report said they were replaced but I found no evidence the engine had been entered. Anyone knowledgeable of this engine and have any idea if I have a problem? Is this one to get rid of?
tia,
ray
tia,
ray
It would be interesting to know if the same particles are found in high quantities within the oil filter, suggesting they circulate as opposed to being localized to the oil pan. Offhand, I can think of no likely source of plastic or Teflon based components that would create this situation. Good mystery, keep us posted on your findings.
Oldog, I hate to tell you this, but the plastic pieces are probably from the cam chain guides. These are different from the tensioners. If the Ford dealer said they didn't know about this, they were probably lying to you. It is a very common problem in the SOHC engine, and there was an extended warranty for some model years.
The plastic guides were used in the 4.0's through build date 9-18-98.
I would take it to another dealer, and have the guides replaced. If they fail, the valves will hit the pistons and the engine is then beyond a cost-effective repair.
Good luck with it.
Don
78 Bronco Ranger XLT, 351M, 4-sp, Trailer Special
Good luck with it.
Don
Olddog, I think those chain guides were covered with an extended warranty up to 7 years/100K miles. I would take it to another dealer, and try to have it fixed. They will replace the plastic guides with aluminum ones, which are much more durable.
jayton4
Modular V8 (4.6L, 5.4L)
32
05-06-2013 07:16 AM
rageoda
1983 - 2012 Ranger & B-Series
09-01-2010 01:19 AM
edward r
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
12-16-2003 05:28 PM
oldogy
11-29-2001 08:10 PM
