Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-26-2008, 12:03 PM
gilllawn is new and has a neutral reputation at this point.
Carb Question
Just replaced a Holley 4180 with all the emissions crap to a Holley 4160 S. I noticed that the kickdown linkage engages much more often then before. How can this be adjusted?
1986 Ford Dually f350 with a C6 Rod style kickdown lever.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-26-2008, 01:47 PM
jburke832 is starting off with a positive reputation.
Hold the kick down lever in the WOT position (counter clockwise as far as it will go). Hold the Carb throttle lever in WOT position.
Insert a .060 feeler guage between the throttle lever and adjusting screw and check/adjust for proper fit.
Needless to say, perform with engine off.
  #3 (permalink)
Old 05-26-2008, 03:55 PM
pipman76 is starting off with a positive reputation.
my 76 460 c-6 doesnt even have a kickdown lever
  #4 (permalink)
Old 05-26-2008, 05:27 PM
what if the carb doesn't have a screw for this adjustment?
  #5 (permalink)
Old 05-26-2008, 07:50 PM
Check the attachement at the tranny and see if you can adjust the rod at that point.
  #6 (permalink)
Old 05-26-2008, 08:39 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
Quote:
You are missing parts then, because all C-6s had kickdown levers.
__________________
Bear 45/70
Gimp Racing
  #7 (permalink)
Old 05-26-2008, 08:45 PM
Bear 45/70's Avatar
Quote:
I've never seen a Holley made for a Ford motor with a C-4 or C-6 that didn't have the adjustment screw on it. Never heard of a 4160S carb either. Maybe you mean a Holley 4160 series carb and the list number is 1850S. 4150, 4160, etc are carb series numbers which designate whether the carb have a secondary metering plate (4150) or not (4160). The List number on the air horn is the actual part number of the carb, like 1850 or 1850S.
__________________
Bear 45/70
Gimp Racing
  #8 (permalink)
Old 05-26-2008, 08:48 PM
It's a 4160 and it does have the throttle for the kickdown lever but I don't have anyway of adjusting it. There is a seperate kit you are supposed to be able to get I believe it's a 20-40 (Holley Number) but I'm not sure. Thus the reason for the question. I cannot adjust the kickdown linkage any other way unless I have the screw that should be on the carb but isn't. Thus my question.
  #9 (permalink)
Old 05-26-2008, 08:50 PM
i didnt say it never came with a kickdown lever i knew all had one at some point i just said mine doesnt have one now .the c-6 has been in my truck for years with out it ,they are good to have for passing gear
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
