Archived MI Buy/Sell/Trade Ads
#31
Originally Posted by Toyman
Just a thought Jim, did you happen to pull the cable off and make sure that it is not broken. I have seen that happen before.
Toyman
Toyman
#32
02 F-150 4wd parts left over
Front and rear 3.55 gears with rear posi carrier. 35,000 miles I went to 4.56.
4 stock Goodyear tires 265/70/17 with 35,000 miles. Great spare or replacement tires.
#34
Front suspension from a 77 F150, all of it. D44 axle, springs, shocks, arms, steering linkages from the pitman out. Even the front brake rotors/calipers. $175/obo.
Bring a truck and your tools, I ran out of sockets big enough to complete the teardown on the front end, and this needs to go.
If you want the frame and what's left of the cab, make an offer. The 9" rear is spoken for. The front LH fender is OK, there's an extra front grille surround, an extra T18 2WD, fan shroud, clutch fan, regular fan, an extra cool(I think, it's bigger than the stock one) rad that needs re-cored, the front RH fender has a couple holes but seems solid other than that.
Cab has floor trouble and rear corners are going. Windshield has a leak or two as well. Email or PM if you want some quick pics, I'll take some this afternoon when I get home.
#36
It wasnt the cable it was the motor servo was sticking bad bearings I guess found a good one at the salvage yard for $10 works great.
#37
Front susp. is on hold, but all the rest is still here, plus the steering column, driveshafts, NP435/205 combo, pedals, dash pad, dash, instrument cluster, clutch, flywheel, starter, side door glass, window regulators, back slider window, tail lights, headlights, bench seat, just about anything else left sitting in the driveway. Send me an email, I'll get pics of what you want to see, make an offer. I would prefer not to ship, but maybe we can work something out.
#38
For sale 78 F150
I am going to part out/sell my 78 F150. The front clip is in good shape, doors are a little rough and need some rust repair, the truck is green and has green interior which is in great shape except for the seat. At present the engine and trans are still in it but are not for sale, they will be going into my 53 some time in the future. Willing to sell it bit by bit or all together (minus engine, trans and drive shaft). I'll post some pictures in my gallery later today.
Thanks and have a great day....
Bob G
Bob G
#39
Toyo Open Country M/T's for sale, 4 35 12.50r20s on 20x10 eagle wheels 1/2 tread with good balance 8 on 170 with spline drive lug nuts, off my 03 I had to sell. four hundies for all cost me over $2000. you can call if int. 2 six 9- 2 seven 1- two 9 three 1.
Joe
Joe
#41
I am looking for steering column and shaft that will work on my 1978 f250 4x4. If anyone has either of these parts please let me know. Also having trouble figureing out what speedo gear I need i know my truck has a c6 trans has 4:11 gears in the rear and 35" tires. If anyone can help on either let me know. My e mail is rgenow05@yahoo.com Thanks
#42
Update, 9/19/08
WANTED: performance parts for 5.0 and/or 2.3, Explorer axles.
FOR SALE:
Updated version, again.
FOR SALE:
- BW1356 electronic t-case
- D80E heads, 30K miles, look great
- computer from '95 F150 4x4, manual, 5.0
- computer from '93 F150 4x4, auto, 5.0
- 1-2 year old A/C condensor from '92-96 F-series, looks new, clean
- 4.9/5.0/5.8 flex plates for E or F-series
- '84 Bronco-II parts Pics of '84 B-II
- transfer case
- 2.8 v6, 90,000 runs
#43
Michigan Chapter Buy/Sell/Trade Ads
Chapter Buy/Sell/Trade Ads: Each chapter will have one (1) thread for chapter members to list items wanted, for sale or for trade.
The rules for posting in this thread are as follows:
Archived MI Buy/Sell/Trade Ads,,, https://www.ford-trucks.com/forums/7...trade-ads.html
- Only Ford truck related items and automotive tools & equipment can be listed.
- Only one picture is allowed per post, per item. If additonal pictures are necessary, place a link in your post to those pictures. Additional posted pictures will be removed without warning.
- You must have your private messaging (PM) turned on and be able to receive PM's to post an ad in the Chapter thread. If you do not, your post will be removed.
- Use the PM or email system to conduct all discussion and transactions regarding the item(s). You can post your interest in the item(s) and that you’ll contact the seller but no discussions. Keep it short.
- If you post an ad, please reply that you found, sold or otherwise disposed of the item.
- The buy/sell/trade thread will be purged periodically for old postings. Generally every 30 to 60 days.
- You need to be an active Chapter Member on FTE to post a wanted, for sale or for trade item(s). No Exceptions.
- You must have permission from the Chapter Leader or a Regional Moderator to post an ad in a chapter that you are not a member of.
- If you are new to FTE (less than 15 days) or have less than 25 posts, you must contact the Chapter Leader for permission before posting an ad.
- Your ad or reply to any ad is subject to editing or deletion at discretion of the Chapter Leader, Moderators or Administrators of FTE.
- Commercial advertisements are strictly prohibited.
#44
I have a 100 gal transfer tank...also a tuthill hand pump that needs a new hose and rebuild
225.00 OBO
pic here
225.00 OBO
pic here
