Archived IA Buy/Sell/Trade Ads
on
1 Post
Fuel injection off an 89 Bronco with a 302/auto/4wd....2 pc aluminum intake with injectors. switching it to carb and putting it in my mustang. distributor would also be for sale of it too if you need one.
make me an offer...
looking for a pre-93? Cummins diesel for a buddy of mine to replace his bowtie's 6.2 diesel, along with the tranny and t-case if possible.
make me an offer...
For Sale: '77 Lincoln 460 w/C6
Lincoln 460 w/C6. Around 80k miles and ran fine before pulled a few years back. Stored inside and turns over fine.
Complete minus carb. Has alt brkts, A/C brkts, A/C pump and hoses, P/S brkts, exhaust manifolds, starter (core).
Asking $200 obo. Delivery might be possible depending on distance.
1974 F100 4x4 - Parting Out
I have a 1974 F100 that I am parting out. It's a regular cab 8' box 4wd NP203 t-case, C6 auto, 360 FE. Glass is all good, good seat, decent body panels for here in Iowa, cab is solid, race track trim, 100 mph gauge cluster, ....
If you need something let me know and I will see if I have it and get some pictures to you.
Thanks,
Thanks,
Thanks,
Thanks,
Jeff,
The box and tailgate are in decent shape. It has the typical rust issues above the fender wells and on the front corners of the outside of the box. The inside has some surface rust on the floor and some scratches in the paint on the sides that have some surface rust. Otherwise no rust thru or weak spots that I have seen.
The 360 I am pulling out of my daily driver in the next couple weeks. It runs ok but the head gasket is gone. Not sure how many miles are on the engine, but the P.O. was the original owner and he says he never rebuilt the engine and the odometer has only rolled over once. So I am guessing it has 134k on it. So I would say it's due for an overhaul, but if your just looking for something to drop in and run with little work it should be good for a little while.
If your interested in any of these things let me know. I have some pictures already of the box and tailgate I could send you. PM me your e-mail address and I will get them sent to you.
Thanks,
Thanks,
i have a complete 76 f250 highboy with dana 44hd diff dana 60 rear new pass side u-joint and stub shaft re[laced spindle with used new bearings truck what i beleive is rebuilt 360 was told 390 by po has headers holley carb body is restorable or run as is has white spokes one new 16x8 new tires maybe 1000 miles on them
Speaking of 360/390s. I have a 360 from a 1974 F100 that I just pulled. It ran when removed, but needs a head gasket. It is a complete engine. I also have a C6 for the same engine that needs a rebuild, was getting weak. And then a NP203 transfer case that worked perfectly. I need this stuff out of my garage. If you are interested let me know, I will be going to the scrap yard to get rid of it as soon as I get my truck road worthy.
Was at the local winshield repair place this morning and the guy has a very nice
1999 F250 XLT Supercab, long box, 7.3 Diesel, Automatic, 2 wheel drive for sale.
It's very clean, 153,000 miles, new ball joints and a new torque converter, could
use some new tires. He told me to go take it for a spin while he fixed my windshield...
runs great, no obvious issues... The truck spent most of it's life outside the rust belt,
so there was zero rust on it.
He'd like to get $6,000 for it.
Anyone interested, send me a PM and I'll send you his number...
Truck is located in Sioux City, IA.
#29
I can't think of anyone off the top of my head, but I'll keep it mind. I wouldn't mind having one for a toy, but my wife would probably beat me with a club if I brought it home...
Where abouts are you located?
