Archived Buy/Sell/Trade ADs - Page 2 - Ford Truck Enthusiasts Forums
Utah Chapter Join Chapter, Leader:
Closed Thread
Old 08-06-2010, 12:13 AM
frankensteined_67's Avatar
frankensteined_67 frankensteined_67 is offline
frankensteined_67 is starting off with a positive reputation.
67 f100 chassis
any one need a rolling chassis. or just the 352FE engine, 9" rear diff, manual grear box. let me know im just trying to part out the rest of my 67 f100 all must go.
Last edited by SteveBricks; 08-09-2010 at 09:51 PM. Reason: Moved to buying and selling thread
Old 04-03-2011, 03:31 PM
carbs & chrome's Avatar
carbs & chrome carbs & chrome is offline
carbs & chrome is starting off with a positive reputation.
9" Ford rear - SOLD!!!
Old 04-05-2011, 12:17 AM
2 1953 - 56 columns and boxes - SOLD!!!
Old 04-12-2011, 03:18 PM
SOLD!!!
Old 04-25-2011, 11:01 AM
1953 - 1956 column - SOLD!!!
Old 10-28-2011, 06:23 PM
wooddyusa's Avatar
wooddyusa wooddyusa is offline
wooddyusa is starting off with a positive reputation.
Parting out....79 F350 2wd at 460 v8
I recently moved to Utah and never did register this truck here. I drove it out but never got it to pass emissions or safety. I bought a 78 F250 recently and have used some of the parts from it but there are much more available. Im in Riverton. Let me know if you are interrested in anything. tjwoodd@yahoo.com
Old 10-29-2011, 12:08 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Moved to chapter buy/sell thread
Old 10-29-2011, 11:18 PM
wooddyusa's Avatar
Thanks. Sorry about that.
Old 06-26-2013, 12:15 PM
Parting out 223 motor and 3 spd trans
I'm parting out a 223 if anyone needs something. This is out of my Ford F100, but could also work in a car. It was a rebuilt motor that I drove for maybe a couple thousand miles. Block now has a crack so that's why I am parting it out. Here's what I have:
-solid intake (usually rot out in heat riser) = $40
-rebuilt rocker arm assembly ONLY (head sold) (early valve cover style) = $45
-chrome (old - some scratches but still shines nice) valve cover w/ breather & rocker cover = $75
-oil pan = $35
-road draft tube = $5
-misc gaskets = $5
-fan = $15
-starter = $30
-water pump pulley = $15
-push rods = $10
-water pump = $15
-160 degree thermostat (new) = $5
-rear motor / bellhousing mounts - rubber (only a couple hundred miles on them) = $10
-stock oil dipstick = $5
-header & dual exhaust w/ Smithy's glasspacks = $100 (Sold pending pickup)
-generator = $40 (Sold pending payment)
-Holley 1904 w/ both glass and metal bowl & hard fuel line = $45 (SOLD)
-Carb spacer = $5 (SOLD)
-distributor w/Petronix, new points/condenser, new cap/wires, hard vac. line = $45 (SOLD)
-thermostat housing & new / never installed thermostat = $10 (SOLD)
-upper and lower hoses = $5 (SOLD)
-timing cover = $15 (SOLD)
-front motor mount bracket and pad = $10 (SOLD)
-oil bath air cleaner = $45 (SOLD)
-fuel pump = $10 (SOLD)
-oil pump = $10 (SOLD)
-oil pump pickup = $10 (SOLD)
-flywheel cover (upper & lower) = $15 (SOLD)
-bellhousing (truck style) = $25 (SOLD)
-flywheel = $25 (SOLD)
-3 spd trans = $50 (SOLD)
-clutch fork = $10 (SOLD)
-3 spd column shift assembly = $10 (SOLD)
I'm sure I missed some things. If you need it and it's not listed please PM me and I'll see if I have it.
Prices DO NOT include shipping. I will get actual shipping on items. I will ship cheapest between USPS and UPS - unless you have a preference. Anything large ( esp. trans, or the whole lot of parts, will be up to buyer to arrange). 70 lbs is weight limit for USPS. Located in Utah.
If you want all or a majority of this we can make a better deal on pricing.
Old 08-06-2013, 07:04 PM
Sorry I haven't updated in awhile. Still have a few things left:
-oil pan = $35
-misc gaskets = $5
-fan = $15
-starter = $30
-push rods = $10
-water pump = $15
-generator = $40
-carb linkage / pivot that attaches to intake = $10
-clutch arm and pin (I switched to automatic) = $25
-header = $100 (Sold pending pickup)
Old 08-11-2013, 07:35 PM
fordtruckdude98 fordtruckdude98 is offline
fordtruckdude98 is starting off with a positive reputation.
*Moderator Edit*
Per rules in first post, only Ford truck related items and automotive tools & equipment can be listed.
Old 10-23-2013, 09:53 AM
Not much left:
-misc gaskets = $5
-fan = $15
-generator = $40
Closed Thread
Ford / Navistar Stanadyne IP Model #'s w/HP Ratings - Complete IDI Tuning Info FORDF250HDXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 43 02-06-2017 08:19 PM
need to buy a 73-77 front grill and headlight and other chorm trim vastine 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-29-2016 09:06 AM
DB Electrical Alternator - from bad to worse bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 41 03-22-2016 10:52 AM
Pump Number Question - F4DB 28315069 edzeb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 05-22-2015 02:56 PM
injection pump swap from 6.9 to 7.3 IDI turp Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 01-20-2013 02:40 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
