Archived Buy/Sell/Trade ADs - Page 4 - Ford Truck Enthusiasts Forums
Nevada Chapter Join Chapter, Leader:67 Olfthfl
Closed Thread
  #46
Old 05-28-2008, 07:31 PM
vegasmike250's Avatar
vegasmike250 vegasmike250 is offline
vegasmike250 is starting off with a positive reputation.
stock suspension off an 02 f-250 4wd crew cab diesel. everything is there including stock pitman arm and everything else, no problems with anything here.
let me know if you want anything, everything is make an offer.
Also a set of 35" tires on 16.5" rims. tires are 35x12.5/16.5 BFG mudders tons of tread left, $500 obo
thanks,
-Mike (702)604-0103 or thadogg14@yahoo.com
  #47
Old 06-24-2008, 01:16 PM
05XLT's Avatar
05XLT 05XLT is offline
05XLT is starting off with a positive reputation.
I've got a set of OEM 16" 2005 Explorer rims. I have them on craigslist for $600, Would anyone be interested? Make me a reasonable offer. They are 5x114.3
  #48
Old 06-25-2008, 03:46 AM
1972-34ton 1972-34ton is offline
1972-34ton is starting off with a positive reputation.
Manifold, Left, HD, '76, 352, type with exhaust hole
For sale cheap to local LV person:
Exhaust Manifold, Left (driver's side), HD from Uhaul F-350, '76, 352, type with exhaust hole crossover in the middle. It is the light one in the two pictures. Looks to be in perfect shape. This is the unusual "ribbed" part. It is not the 360/390 piece (at least for a 2bbl manifold in '72).
Kevin
Please abide by the Forum Rules: ONLY PM me. No questions in postings.
  #49
Old 10-28-2008, 05:37 AM
alanco's Avatar
alanco alanco is offline
alanco is gaining momentum as a positive member of FTE.
'56 Cab, Chassis, Fenders, Bed, Other Parts
Posted in Main Classifieds
  #50
Old 12-13-2008, 01:08 AM
cburch cburch is offline
cburch is starting off with a positive reputation.
Looking for 2nd row captains chairs to replace the bench seat in my 2000 Ford Excursion. If anyone knows of a wrecked Ex, or someone who may have some seats I would appreciate the opportunity to purchase.
Thanks,
clint
  #51
Old 02-11-2009, 10:36 PM
racerchick21's Avatar
racerchick21 racerchick21 is offline
racerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to behold
1953 f100
Hi all!
If anyone is interested in this:
Please let me know. He has the original title, it's a complete restoration project. $1200
  #52
Old 06-10-2009, 01:02 AM
Pwrstrkd"X" Pwrstrkd"X" is offline
Pwrstrkd"X" is starting off with a positive reputation.
6.0 Transmission cooler (26 row) "NEW" $225.00 Located in Las vegas.
  #53
Old 06-11-2009, 10:18 PM
Quote:
Originally Posted by pwrstrkd"x" View Post
6.0 transmission cooler (26 row) "new" $225.00 located in las vegas.
sold!!!!sold!!!!!!
  #54
Old 12-14-2009, 03:04 PM
jarod17's Avatar
jarod17 jarod17 is offline
jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.
Lightning and F-series Gauge clusters
I am selling the two gauge clusters for my truck.
The top cluster is out of a '97 F-250 it has flame face and the 120 MPH speedometer out of a '94 Lightning. This was my main cluster and everything work on it. I am selling it because I have replaced it with the cluster out of a '96 mustang GT.
The lightning speedometer in this cluster had what appeared to be stock size tires and 4.10:1 gear ratio. My truck has 3.55:1 gear ratio and was reading 10% fast, ie, 66 mph on the speedo was really 60 mph. So if you have 4.10 gears w/stock tires or 3.55 gears with oversize tires you may not need to reprogram the psom.
The bottom cluster is the cluster from the '94 Lightning that I took the Speedometer out of. I tested this last year but the Lightning has a different ABS setup and the ABS light was constantly on. Rather annoying so I used the '97 cluster with the Lightning speedometer. The speedometer is the original out of my '96 F-250.
As you can see both of these clusters have the tachometer in them. The Lightning cluster may work as a cluster swap if you want to swap out a non-tach cluster. Up to you to find out ABS compatibility. Or you can just remove the ABS light, Your choice.
I am asking $100 for the top cluster and $60 for the bottom cluster. FREE shipping in the 48 states. If you are going to be in the Wendover, NV. area we can arrange local pick up. I am interested in trading as well. If you want to trade I would be interested in hearing what you have to trade.
If you are planning on going to the Chapter G2G in Vegas at the end of Feb. I can deliver it then if you want. Any questions feel free to PM me.
  #55
Old 03-03-2010, 03:39 PM
Flathead Red's Avatar
Flathead Red Flathead Red is offline
Flathead Red is starting off with a positive reputation.
I have two original rear fenders for a 40 Ford P/u. There are a few small spider cracks but otherwise good condition. PM me for pictures.
Red
  #56
Old 07-30-2010, 02:16 PM
Bayer-Z28's Avatar
Bayer-Z28 Bayer-Z28 is offline
Bayer-Z28 is starting off with a positive reputation.
F/S F/T ... 95 F150 XLT 2WD .. *VEGAS*
Located in North Vegas, Nellis AFB.
1995 F150 XLT 2WD (Mostly stock) .... runs great.
5.0L (MAF)
MSD Cap, rotor and coil, plugs ("6 litre" tune up)
Green-ish base coat paint (sun damaged, previous owner)
162k miles and WELL maintained
Mobil 1 Filter and oil
12v Mod (Headlights)
E-Fan
4R70W trans (well maintained)
Dual tanks
Front fuel pump is 5 months old
Water pump is 3 months old
New rad cap (3 months old)
New upper and lower Rad hoses (3 months old)
Toyo Open Country Tires are 6 months old
Slotted FT rotors, newer seals and bearings (6 months old)
Rear drums are 6 months old
RP Rear oil
Spray on Bed Liner done in New Mexico (BULLET PROOF!!)
DUAL brand CD player (Cheap-o)
Ft Ball Joints are 3 months old
Idler + Tensioner pulley are 3-4 months old
Serp belt is 3 months old.
Battery is a year old
Starter replaced around August last year.
Dist + PIP replaced last year
Remote mount TFI (Factory)
Flowmaster muffler (pass side, single in dual out.. Log manifolds and stock cats. Passes CT Emissions with FLYING colors!)
Frame and undercarriage are in great condition. Aluminum wheels are oxidized from one New England winter. New crack on top center of windshield, about 6" long. Insurance won't cover it. I think it was from the heat. Noticed it about 2 weeks ago before I left.
Truck was originally bought and delivered in New Mexico for the 1995 Model year, I drove it back to CT in 2009 and then back out the Nevada in 2010. I BELIEVE I am the second owner. I have owned this truck for about four years.
Tailgate has one small dent toward the top, but closes fine. No major body damage. One small dent on the front of the hood from me. Bumpers are still clean and like new. .... Bench seats......Tan interior. Cruise control... OD WORKS.. PW, PL, PM. .. Sliding rear window.
I'm looking for a 95~ish Bronco to take back up to PA with me when my g/f and I move in together in 6-8 months. My F150 is for sale or For trade for Bronco with a 5.8, auto, 4wd. Or whatever people feel like offering.
Serious inquiries only, I have the title but I am an Over The Road Truck Driver, so I will be back in NV in about 6 weeks. The truck is at a friend's house right now so if someone is interested, I can mail the title back to LV for the buyer.
Asking $2600 for the F-150, OBO. Email through my account here. Send two emails, just to be sure my spam filter didn't snag it.
Pic is 3 months old. Taken in CT.
Last edited by SteveBricks; 07-30-2010 at 02:33 PM. Reason: Moved to For Sale/Trade/Wanted thread
  #57
Old 07-24-2011, 11:22 AM
BeerMeNow's Avatar
BeerMeNow BeerMeNow is offline
BeerMeNow is starting off with a positive reputation.
Wanted - 2006 Front Bumper
I am looking for an 05-07 front bumper good condition. Really just need the lower half and not the color matching piece but will take anything.
  #58
Old 09-30-2011, 11:54 AM
67 Olfthfl's Avatar
67 Olfthfl 67 Olfthfl is offline
Nevada Chapter LDR
67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation67 Olfthfl has a superb reputation
No longer for sale
No longer for sale!
  #59
Old 10-24-2011, 02:03 AM
BeerMeNow's Avatar
Anyone? Maybe know where to look for one.
  #60
Old 10-27-2011, 10:35 AM
RocketMonkey28's Avatar
RocketMonkey28 RocketMonkey28 is offline
RocketMonkey28 is starting off with a positive reputation.
I'll see what I can find.....
Closed Thread
Archived NC Buy/Sell/Trade Ads FTE Trigger North Carolina Chapter 153 09-06-2016 07:56 PM
Archived MD Buy/Sell/Trade Ads FTE Trigger Maryland Chapter 189 05-13-2016 12:48 PM
Archived VA Buy/Sell/Trade Ads FTE Trigger Virginia Chapter 81 07-04-2015 01:28 PM
Archived AL Buy/Sell/Trade Ads F2504x4 Alabama Chapter 28 03-21-2014 11:35 AM
SC Archived Buy/Sell/Trade Ads FTE Trigger South Carolina Chapter 20 04-24-2013 08:49 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
13018, 16x10, 2558516, 411, 61, alloys, change, eagle, excursion, ford, henderson, nv, ranchero, reprogram, rims, sell
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
