Diesel Fuel Longevity
Diesel is now $5.25+ a gallon here. My truck is not being driven like it once was and I was curious as to how long diesel will go before turning bad. I am trying to keep the tank filled completely up, and refilling once I run about a ¼ tank out of it. At this rate I am using about a ¼ tank every 4-5 weeks. Will the occasional 6-8 gallons a month I refill it with be enough to keep the fuel “fresh?” Thanks,
The ULSD is real susceptable to biological growth. They sell an additive to kill it off and prevent more growth. That is the only real problem with older fuel in diesels. I have an outside storage tank on the farm and treat it once a year. I have diesel in there that was bought last fall and no issues with it.
on
you can get ULSD (ultra low sulfur diesel ) at any fuel stop..thats what diesel is called now.you can thank EPA for that...it used to be LSD (low sulfur diesel )... DK makes stuff to keep things clean..
I get my BIO-Treatment from my bulk fuel supplier, but one of the stations in town sells it also. One quart teats a 300 gallon tank. Any auto parts store should also be able to get it if they don't stock it already.
I get my biocide fuel treatment at West Marine, or you can get micro-organism killer at any good Marine place, as marine diesel systems are a lot more subseptable to mold and other crap due to the constant moisture environment. I paid about $24 for a bottle, and I also use Diesel Kleen gray every tank or so. However probably the best system cleaner is biodiesel.
WMRiceman
07-06-2021 08:00 AM
ttexastim
23
01-21-2009 10:51 PM
