Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-25-2008, 10:55 PM
83maverickf-100 is starting off with a positive reputation.
valve cover sludge?
on an 83 carbebed stock engine that has had yearly tune-ups all its life how much sluge should it have normally in the valve cover?
-tried a few system cleaners, before takeing off to clean
-the middle two cylender had the most sludge others had sludge free spots
-performance millage get back from cleaning? how much does sludge rob?
-never been off before either
-mean anything the middle was the dirtiest?
input apreiciated thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-25-2008, 11:10 PM
TheL36Driver is starting off with a positive reputation.
Short trips, infrequent oil changes and poor crankcase ventillation = Sludge.
  #3 (permalink)
Old 05-25-2008, 11:47 PM
stepped on regularly too "clean up" and oil changeged every 3000-3500
  #4 (permalink)
fmc400's Avatar
fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.
Engines get old, valve covers leak. Pull the valve cover, replace the gasket, reseal.
  #5 (permalink)
Old 05-25-2008, 11:51 PM
did that yesterday lol forgot to mention
  #6 (permalink)
Old 05-26-2008, 12:02 AM
but i do only drive all of ten miles a day
  #7 (permalink)
Old 05-26-2008, 12:10 AM
Quote:
There it is dude. You don't get it up to operating temperature long enough to 'burn off' the moisture build up from combustion byproducts.
Start changing oil about every 2K miles and use Shell Rotella. JM .02
Canada = Cold...............................Don't help either.
  #8 (permalink)
Old 05-26-2008, 12:31 AM
does run about an hour or two at a time on weekends not enough? does synthetic help
  #9 (permalink)
Old 05-26-2008, 04:27 AM
srercrcr is starting off with a positive reputation.
Synth does clean stuff out with time, but you may develop gasket leaks by switching over with high mileage. I like, but some don't, running a can of engine flush in the oil prior to dropping the oil out. Smells like kerosene to me, but with 5000 mile oil changes, you won't see any sludge under my valve cover.
__________________
Steve Robbins
'83 XLT Super Cab Long Bed 300-6 (20 mpg hwy) 4OD 3.08, one-owner ordered from the Factory in May '83 with a page-full of options, 175000 miles, all stainless exhaust. Take a look.....
http://s45.photobucket.com/albums/f88/srercrcr/Ford%20F150/?action=view&current=FordF15083.jpg
  #10 (permalink)
Old 05-26-2008, 09:18 AM
fmc400's Avatar
Sorry maverick, I thought you meant sludge on the outside, not underneath. As far as that goes I agree with everyone else's comments.
  #11 (permalink)
Old 05-26-2008, 11:11 AM
Quote:
Back in the old days (pre 1970), the plan was to drain the oil and fill the engine completely with kerosene or diesel (remember $.15/gal diesel?). Run it at idle speed for fifteen minutes or so. Not in your driveway as kerosene would be puking out the oil fill. Refill with regular oil and change filter. (A '57 Desoto hemi takes a full 5 gallon can to fill.)
Another plan is to fill (to normal level) with ATF type F (whatever is cheap) and run it at light load (no trailer towing) for 100-200 miles and drain. Also works very well on lawnmower engines.
  #12 (permalink)
Old 05-26-2008, 10:15 PM
no problem fmc400 honest mistake didn't cost me anything
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
