You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
... it is relative to the speed I am going.... it will continue till a complete stop is attained... meaning as I stop it gets slower until it is almost like a croak as the tire comes to a stop.... it is only one spot on the tire that makes it squeak... as that part of the tire comes in contact with the road.... it squeaks these are new tires on new rims... they did not do this when they were put on 5/21 ... any ideas??? anyone....
__________________ "Make way for the positive day" ... Steve
2004 F150 XLT w/AEM CAI and Magnaflow Exhaust
Nitto Terra Grappler Tires mounted on 18" Hela Black Spoke Rims w/ Machined Lip , Nasta Billet Grill
Ma., N.H. & Mid Atlantic Member
First thing that comes to mind is a loose lugnut....
Next maybe the wheel weights causing the squeek..
Or does it have hub caps? maybe the problem is with them.. If it does I would take them off and see if the noise goes away...
Also with new rims they may be rubbing if not the same backspacing..
Just a few items to check out..
__________________ Don #3 SlackMaster Chapter Leader of the Massachusetts Chapter
Join the MA Chapter Here Currently own: 2006 F350 Lariat CC Super Duty, 6.0 L Diesel FTE Fraternity OF Blue Max
checked all of the above... it appears to be the tire... a friend said it was the bead of the tire....
found out that there are two lips on my wheels and if the tech did not mount them right the tire will flex at this point and cause a squeak... company (kmc) said that it happens in 1% of the tires mounted... causes no harm... have to unmount tire and re-mount... find out this afternoon if he is right....
Well that's an easy fix..
Hope it works out for you..
That would be an easy fix...my tire guy thought it was probably the loose nut behind the wheel!!!
__________________ Member of the Massachusetts Chapter and Number One Winter Hater!!!
Is that what he found fixed your car???
