Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 06-07-2008, 11:27 PM
fleetbob1's Avatar
fleetbob1 is starting off with a positive reputation.
I filled up the block through the t stat housing removed t stat
and filled rad I will run it tommorrow to see if the problem is fixed
I think the pump was just pumping air, the block took over a gallon of coolant to fill........
Sponsored Links
To remove this ad, register today!
  #32 (permalink)
Old 06-13-2008, 12:00 AM
fleetbob1's Avatar
ran it again tonight i think i am air bound
how the fu#k do i get the air out of the system
__________________
  #33 (permalink)
Old 06-13-2008, 04:59 PM
mudslingin'78's Avatar
mudslingin'78 is starting off with a positive reputation.
The radiator might be mounted too high in regards to the motor. For some reason It has to be a certain height.
  #34 (permalink)
Old 06-14-2008, 12:34 AM
fleetbob1's Avatar
i dont think thats the problem its only about 8 inches higher then the highest point on the engine
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
