Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-25-2008, 10:29 PM
CoachRobb is starting off with a positive reputation.
need help!
I have a 302 that I rebuild about 6 years ago but has only about 2000 mile on it. the car was wrecked and been setting. I put marvel mystery oil in the the cylinders before i stored it. what would need to be done before I put it a truck. also I have a set of 79 351w heads would this increase hp or something else better this will be a daily driver. thanks for your help.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-25-2008, 11:45 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
What year is the motor? 79 heads are about the worst you could possibly have(smog era), if your motor is significantly older or newer than that it's got better heads already. If the motor turns over freely it's good to go.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
