New Hampshire Chapter Join Chapter Leader: 7283-F250
new left tires are squeaking...
Old 05-25-2008, 09:49 PM
barecove's Avatar
barecove
barecove is offline
... it is relative to the speed I am going.... it will continue till a complete stop is attained... meaning as I stop it gets slower until it is almost like a croak as the tire comes to a stop.... it is only one spot on the tire that makes it squeak... as that part of the tire comes in contact with the road.... it squeaks these are new tires on new rims... they did not do this when they were put on 5/21 ... any ideas??? anyone....
Old 05-25-2008, 10:28 PM
donjamer's Avatar
donjamer
donjamer is offline
First thing that comes to mind is a loose lugnut....
Next maybe the wheel weights causing the squeek..
Or does it have hub caps? maybe the problem is with them.. If it does I would take them off and see if the noise goes away...
Also with new rims they may be rubbing if not the same backspacing..
Just a few items to check out..
Old 05-25-2008, 11:03 PM
Towmanjbo's Avatar
Towmanjbo
Towmanjbo is offline
Put one on the other side then you'll have stereo tires instead of the old radio tires. LOL
Old 05-26-2008, 03:35 AM
barecove's Avatar
barecove
barecove is offline
checked all of the above... it appears to be the tire... a friend said it was the bead of the tire....
Old 05-28-2008, 08:07 AM
barecove's Avatar
barecove
barecove is offline
found out that there are two lips on my wheels and if the tech did not mount them right the tire will flex at this point and cause a squeak... company (kmc) said that it happens in 1% of the tires mounted... causes no harm... have to unmount tire and re-mount... find out this afternoon if he is right....
Old 05-28-2008, 08:19 AM
donjamer's Avatar
donjamer
donjamer is offline
Well that's an easy fix..
Hope it works out for you..
Old 05-28-2008, 09:22 AM
BIGKEN's Avatar
BIGKEN
BIGKEN is online now
Received 7,085 Likes on 4,176 Posts
That would be an easy fix...my tire guy thought it was probably the loose nut behind the wheel!!!
Old 05-28-2008, 09:40 AM
donjamer's Avatar
donjamer
donjamer is offline
Is that what he found fixed your car???
ToMang07
34
06-26-2011 12:58 PM
TOW II
1983 - 2012 Ranger & B-Series
10-31-2009 09:19 PM
sjniii
15
10-24-2009 10:01 PM
Archangel007
05-28-2008 09:34 AM
fawey1
17
05-08-2005 09:46 PM
Quick Reply: new left tires are squeaking...
