Help With Codes
Help With Codes
hi guys, truck still idling super rough. got a scanner, but don't understand some of the codes. this is what came up.
31 - chilton says PFE, EVP, or EVR - code manual says EGR sensor or EVAP control system low voltage - i ordered a EGR sensor/will install tommorrow
21 - chilton says ECT out of self test range - manual says cooling temp sensor - i replaced coolant temp sensor
40 - can't find this listed anywhere
31 - again ?
35 - chilton says PFE or EVP circuit above closed limit - manual says no EGE position signal RPM low or EVAP control system fault - no idea what this means
41 - chilton says HEGO sensor circuit indicates lean or no HEGO switching detected - manual says HEGO (HO2S) sensor low/system lean - i don't lnow what this means
PLEASE HELP I'M HAVING TROUBL FIGURING OUT WHAT ALL THIS MEANS
31 - again ?
If you have a coolant sensor that is bad the engine may be not be switching from open loop (cold engine - engine runs on predeterimened program - no sensors input used) to closed loop (engine uses input from sensors). That may be why the oxigen sensor fault is coming up. Keep track of the codes you now have. Make the changes - replace the senors and such - clear the codes and see which one come back after the repairs.
HEY GUYS,
replaced thermostat and engine coollant temp sensor.ran the truck 15-20 min was still idling rough. let it sit a couple of hours and then it ran much better. pulled the codes again and got 11 - 10 - 21c. am i correct to believe this means system OK and that 21 was the last code tripped?
It's been a while since I've messed with mine. If I remember right 11 means the system passed. Are these codes with the engine off key on or with the engine running?
If you are still getting the coolant sensor fault check your wiring, connections and reference voltage going to the sensor.
Did you clear the codes after putting on the new sensors? Was the engine warmed up when you tested it?
SideWinder4.9l
07-30-2011 08:29 PM
Skidly
13
04-09-2005 01:19 AM
