Headlight Adjustment - Ford Truck Enthusiasts Forums
Old 05-25-2008, 12:20 PM
DABTX DABTX is offline
DABTX is starting off with a positive reputation.
Could someone tell me where to start:
I've replaced the headlight assemblies on my 1997 F350, but I'm not sure how to properly adjust the headlights before I put the headlight doors (bezel) back on.
I looked thru the forum, but I found no information except for the removal of the headlight door (bezel).
Thanks in advance
Old 05-25-2008, 12:45 PM
flareside_thunder flareside_thunder is offline
flareside_thunder is starting off with a positive reputation.
IIRC, there should be hex head screws with torx bit holes in the middle of them...black screws......don't know if that help or not.
JR
Old 05-25-2008, 03:58 PM
Thanks, flareside_thunder. I'm sorry, I guess I should have been a little more specific.
I have identified the screws, but the method of viewing the lights for adjustment is what I was trying find out....is there a standard for projection on a wall or something?
Thanks!
Old 05-25-2008, 05:52 PM
1957F100 1957F100 is offline
1957F100 is starting off with a positive reputation.
im just about the change the headlight assemblys on my 93. i would like to know the answer as well.
Old 05-25-2008, 06:06 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
I do it at night on a road that has a level, straight section that has no street lights and is totally dark. I adjust the low beam just right of center line of the road as follows.
Passenger side low beam straight out in front of itself and the drivers side at the same level but just in toward the center line of the truck so it won't blind oncoming traffic.
Then I adjust the high beams to spread out evenly to both sides. at a higher level then the low beams of course.
Then test drive and make any fine adjustments needed if any.
Have someone stand in front of the light you're not adjusting to block its light so you can see exactly where the one you are working on is pointing.
If people are flashing you when running the low beams you have them set to high.
58 & 59 F100 Headlight Bezels jamhh 1957 - 1960 F100 & Larger F-Series Trucks 2 09-17-2016 02:59 PM
need headlight bezels for f800 ford wants $200 thedieselkid Large Truck 12 09-08-2011 01:44 PM
Headlight bezel wickedinhere 1967 - 1972 F-100 & Larger F-Series Trucks 9 10-13-2009 05:37 PM
HELP 2005 XL to XLT headlight upgrade Tino578 Electrical Systems/Wiring 10 02-25-2009 11:34 PM
1959 f100 headlight bezels sd59f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 02-24-2006 04:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
