Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-25-2008, 11:19 AM
rivrrunner's Avatar
rivrrunner is starting off with a positive reputation.
Dino Fuels Alternatives
Met Jason Crawford of DFA friday....knowledgeable, straight up, no BS kinda guy.
Purchased CCK & HPX (yes it's HP hose) but I was convinced by Jason and my own experience....EBPV line blowin out at 140k, that it would stand up as well if not better than SS.
Tip's: as the instructions point out you do not have to remove all the bolts/parts listed to install the CCK...only removed turbo intake tubing, serpntine belt, and fuel line bracket. It may have taken longer but it goes in.
A 12 mm ratcheting wrench goes over the fuel port plugs makin life much easier especially on the drivers side back one.
plastic underneath the truck is a good thing....beautiful sunny day right...all windows down.....BIG thunder shower-roll up windows = fuel on the plastic/ground...
Noticed a difference in noise and responsiveness after 15 minute burn in...
BTW the CCK has a port for gauge.....my $0.02... well worth the money.
__________________
Brian
E 99 F 350 CC LB SRW 4X4...6637/Pete's,CCV,DFA CCK,HPX,FPR Shim,Zoodad,Tru Cool 4739-1,Warn premo hubs,35'S, 4" lift/level kit, 5" SP, 4 pod "A" pillar, ISSPRO P-T-B, Transgo shift kit, ITP OBA, DP Tuner-GS,NS,S,HI,40 T, Dcel, 60T, 80 E, 120 R, 140 AGG
PAA # 49
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-25-2008, 03:18 PM
John7894 is starting off with a positive reputation.
Sounds like it was fairly straightforward to install. I'll add that to my list to do when I get around to installing that ITP in-tank kit...
__________________
John
2001 F250, 7.3, Crew Cab, Lariat, 2WD. 305,000 miles and counting!!
1987 Mustang hatch, Caged and backhalved race car, 472 BBF, etc... Build in progress.
  #3 (permalink)
Old 05-25-2008, 04:33 PM
F250_'s Avatar
Still learning every day!
F250_ has a great reputation on FTE.F250_ has a great reputation on FTE.F250_ has a great reputation on FTE.F250_ has a great reputation on FTE.F250_ has a great reputation on FTE.
I was beta no.1 here in FTE, and that was last April. Still not the first sign of a leak after over 25,000 miles on the kit.
__________________
Pete
PAA Member #19
'02 F250 CrewXLT, 2WD, 7.3L, 154K
'03 Excursion EddieBauer, V10, 72K
6637 & cover, Fumoto, AIH, zoodad, OilGuard bypass, Cackle-cure, HPX, foil delete, CCV, InTanks, Lift Pump, Boost tube
http://guzzle.rbmicro.com/7pt3/Mods.html Become a SUPPORTER!!
  #4 (permalink)
Old 05-25-2008, 07:06 PM
rivrrunner's Avatar
Pete: good to know...did you use mechanical pressure gauge, and if so what brand?
John: straight forward yes...PITA tight places, yes
__________________
Brian
PAA # 49
  #5 (permalink)
Old 05-25-2008, 10:41 PM
F250_'s Avatar
Brian:
Mine, like I said, was beta #1 and was at that time called the Cackle-Cure Kit instead of the current title of Cross-Connect Kit. Jason was not including a pressure gauge tap when I got mine, so I just tapped into the back of the fuel filter housing when I installed my under-hood gauge. There's a pic in my gallery.
__________________
Pete
PAA Member #19
  #6 (permalink)
Old 05-26-2008, 01:19 AM
rivrrunner's Avatar
Pete: that is a very cool installation w/ the polished bracket....thanx
__________________
Brian
PAA # 49
  #7 (permalink)
Old 07-18-2008, 08:28 AM
davecarpe is starting off with a positive reputation.
Thumbs up DFA Cross Connect (aka Cackle Cure) and HP-X Installed
I just had the DFA Cross Connect and HP-X kit installed on my 2002 Excursion with 7.3L yesterday along with the Flex-a-lite electric fan kit.
I just wanted to add my 2 cents that the mods made a huge difference in the reduction of noise from the engine. It is so much smoother now and quieter at all speeds but especially while driving. I am totally pleased.
I need to get some miles on it and see how fuel economy and power are affected. I am also curious to see if it reduces the tendency to throw fuelk pressure codes if set adjust my Edge Juice to up the fuek dekivery into the cylinders.
Great stuff!
Dave
__________________
Dave Carpe
Newton, NJ
2002 Ford Excursion
7.3 L Powerstroke
  #8 (permalink)
Old 07-18-2008, 08:58 AM
Izzy351's Avatar
Master Debater
Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.
Yup -- it's a good kit. Nice & quiet. If you haven't done the in-tank mods yet, do those too. Mine has been in for a year now and no leaks. No gauge port here either, but I'll be adding one shortly. Haven't even thought about how to go about it just yet, but I'll just do what Pete did. Then copy Brandon's gauge up by the windshield installation... Very handy!!
__________________
  #9 (permalink)
Old 07-18-2008, 09:49 AM
ron's power stroke's Avatar
FORD the rock crusher
ron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to behold
gauge PSI ports in 2 spots the red arrows point to..click on the pix to see more..
i put my gauge in the windshield too..but i made a pod for a cleaner look..i didnt want hoses, holes and back side of a gauge to show when standing out side the truck...
what fluke pressure code are you seeing???
__________________
Early 99 7.3 F350 auto,AFE stage2 5" strait pipe. DP tuner ,140 IDM,Modified 17* HPOP..DI RR
Ryan Casserly's SS stage 2's moded 100% over nozzles
exploded view of a 7,3
Reconstructed 7point3.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
