4.0 misses on hot start, then runs fine - Ford Truck Enthusiasts Forums
Old 12-31-1969, 07:00 PM
Guest
Posts: n/a
Old 01-15-2003, 03:34 PM
zippinz zippinz is offline
zippinz is starting off with a positive reputation.
Both my '94 and my buddy's '95 4.0 V-6 Ranger engines miss for about 15 to 30 seconds on a normal hot start, like when you go into the store for 30 minutes. After "cleaning themselves" out, they perk up and run fine. If the motor has cooled ALL the way down, you start it and it runs fine right from the start.
They will do this on gasahol or regular unleaded - the first ideas I've heard was that the gasahol boils when you shut off thereby causing the problem so I switched to reg unleaded but it still does it.
Mine has 130k miles and his 101k miles, but both have been taken care of, had regular oil changes, and don't seem like tired motors at all. Thanks in advance for any help.
Old 01-15-2003, 09:49 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
Zip, it might be a leaking injector. After shutoff, the injector leaks and floods the cylinder, causing a hot re-start miss. The fuel has time to evaporate after the engine has cooled, giving a normal cold start......??????
00 Explorer Sport 4x2, 4.0 ohv, 5R55E, 3.55 diff
78 Bronco Ranger XLT, 351M, 4-sp, Trailer Special
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1996, 2000, 40, cold, fine, ford, hot, miss, misses, ohv, ranger, rough, runs, start, startup, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
