Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-25-2008, 09:12 AM
guitarnik's Avatar
guitarnik is starting off with a positive reputation.
what motor should i use
i have a friend who own auto shop. he has multiple ford motors lain around so i got to thinkin that i want to rebuild a motor god and right . i have a 351w in my truck(90 f250 4x4 5-speed) should i go with a 351 w, 351c, or mabye 460
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-25-2008, 11:00 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Be aware the 460 will require a different tranny, it's a big block so your 5-speed won't directly bolt up(I don't know if the bellhousings are interhangable), and it's not likely it is built to widthstand the TQ a 460 makes anyway. There's lots more power hiding in that 5.8 you have too, 400ft/lbs TQ and 350HP is attainable with a better set of heads and intake on the 351w... with other supporting parts of course. There is a hugh aftermarket full of upgrades for the Windsor motors, you can pretty much do anyting you want in carbed or EFI versions. Parts for the 351c are much more limited, if you want to keep EFI you'll probably have to modify a carb intake, and there is no real performance advantage considering the heads availabe for the Windsor motors these days.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 05-25-2008, 01:08 PM
guitarnik's Avatar
Smile
thats what i was thinking also. i really like the windsor but was wanting another opinion. what upgrades could i do without hurting my fuel mileage too much, or increasing my compression cause i dont want to buy high octane fuel. if higher compression is the way to go ill do it but if its possible to avoid it id like to.
  #4 (permalink)
Old 05-26-2008, 10:00 AM
Conanski's Avatar
You could install the cam I have and a set of longtube headers, that will really wake the motor up and it's completely compatable with your stock computer. Milage on my motor is 13 city and 17+ hwy, what are you getting?
__________________
Paul O
  #5 (permalink)
Old 05-26-2008, 10:52 AM
guitarnik's Avatar
i figure im gettin an average of 15 on the hwy. no clue in the city. i guess about 12 in the city
  #6 (permalink)
Old 05-26-2008, 10:55 AM
guitarnik's Avatar
i already have longtubes. i was kinda wantin o put better heads on it, or mabye just pport some stock heads or gt40. what cam o you have and where would you recommend getting it.
  #7 (permalink)
Old 05-26-2008, 03:01 PM
Conanski's Avatar
The motor you have has the base cam in it, the later trucks got a bigger cam and produce noticably better power.. and that's with the stock exhaust system. The cam I have is the Crane 444232, it was a common upgrade for the Lightning. Combined with the longtubes you'll have a whole new motor.. powerwise. Just so you know, my combo fully utilizes the stock injectors, if you make the motor flow well enough to need bigger injectors you will be opening an expensive can of worms.
__________________
Paul O
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
