Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-27-2002, 09:46 PM
cubster cubster is offline
Garage is empty, add now
cubster is starting off with a positive reputation.
Throttle Body
Anybody had success with throttlebody modifications? Either swapping for a larger one or boring the O.E. assembly?:
  #2 (permalink)
Old 03-22-2002, 10:13 AM
XLT4Banger XLT4Banger is offline
XLT4Banger is starting off with a positive reputation.
Throttle Body
I didn't mess with the throttle body, but I did construct a new throttle cable hanger. See, my stock cable has so much slack it it, I would have to push the gas petal in half way before my truck would move, and as a result the throttle would only open a little more than half way. On my old Integra, there was a screw that I could use to adjust the tension on the cable, but since Ford engineers are cheap *******s, they just threw on some worthelss plastic clip. I machined a piece of aluminum and replaced the old hanger. Now the cable is extremely tight and 100 times more responsive and I've noticed a significant difference in acceleration with a fully open throtle. Let me know if anyone wants more information. -Kevin
  #3 (permalink)
Old 04-17-2002, 11:14 AM
aksniper aksniper is offline
aksniper is starting off with a positive reputation.
Throttle Body
__________________
~James~
  #4 (permalink)
Old 04-29-2002, 04:23 AM
Drizzt's Avatar
Drizzt Drizzt is offline
Drizzt is starting off with a positive reputation.
Throttle Body
the stock throttle body (and entire intake system flows enough air to supply a 302. the TB isn't the major choke point in our four bangers. you want to see it come alive get a port and polish paired with a more aggressive cam.
an EASIER way to take up the slack on the throttle cable is to go down to where the pedal meets the cable and pull the slack out and use zip ties to keep the cable from running back through the pedal
__________________
2004 Ford F-150 SXT 4.6L 4x4
1986 Ford Ranger 5.0 H.O.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
