Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 05-24-2008, 10:26 PM
BigTrucK72 BigTrucK72 is offline
Garage is empty, add now
BigTrucK72 is starting off with a positive reputation.
2003 F250 headlight assembly removal
I recently purchased some clear corners and finally got around to installing them this memorial day weekend. When I read the manual it said there were some metal clips to remove the headlight assembly.
So I found the clips and was able to easly remove the clip on the passenger side assembly closest to the tire with no prob. But the other metal clip toward the radiator is a little more difficult b/c it's almost a vertical leverage. I feel like that if I put any more force on the tab that I am going to break it. Anyone have any suggestions?
Thanks.
  #2 (permalink)
Old 05-25-2008, 02:43 AM
cartmanea cartmanea is online now
cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.
You won't break the clip, just keep fighting it with a pair of needle nose and a standard screwdriver and it will eventually oblige. Some four letter words helped when I did it. Wiggle it side to side and try to 'walk' it up off the plastic stud. Good luck!
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Icon springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac, Off Road Tech winch bumper
- ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost), Banks Technicooler, Garrett PowerMax VGT
Currently wrecked... again. Rebuild to come.
Tags
1999, 2003, assembly, clips, duty, f250, ford, head, headlamp, headlight, housing, light, removal, remove, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
