Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-24-2002, 10:28 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
Garage is empty, add now
thelonerangerxlt is starting off with a positive reputation.
Oil Leak?
I have a 2.3L in a 92 Mustang. Lately it's been dripping a little oil on the garage floor. I changed the oil last weekend, and narrowed the possible leak sources down to either the valve cover gasket, or a rear main seal. (I'm hoping for the valve cover gasket) My question is: how many miles should a rear main seal last? The engine has about 117K miles on it.
__________________
00 Explorer Sport 4x2, 4.0 ohv, 5R55E, 3.55 diff
78 Bronco Ranger XLT, 351M, 4-sp, Trailer Special
  #2 (permalink)
Old 03-25-2002, 10:34 AM
tomw tomw is online now
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Post Oil Leak?
The rear main should last a LONG time. The cam cover probably will leak 2 to 3 times before the rear main. Also, you should check the block/head sealing as I had oil coming down the side of the block from where the head rested on the block. I retorqued the head bolts with the engine cold, and the oil leak stopped...
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 03-26-2002, 09:41 PM
Oil Leak?
Thanks, Tom. That's what I wanted to hear. I will try re-torqueing the cam cover bolts this weekend, and change it out when the weather warms up.
__________________
  #4 (permalink)
Old 04-29-2002, 04:41 AM
Drizzt's Avatar
Drizzt Drizzt is offline
Drizzt is starting off with a positive reputation.
Oil Leak?
are you sure it's leaking oil and not tranny or p/s fluid? could be a bad pitman seal
__________________
2004 Ford F-150 SXT 4.6L 4x4
1986 Ford Ranger 5.0 H.O.
  #5 (permalink)
Old 05-01-2002, 06:30 AM
Badfunkn Badfunkn is offline
Badfunkn is starting off with a positive reputation.
Oil Leak?
__________________
2006 F350 6.0L Powerstroke FX4
Banks Ram Air intake
Banks 5" exhaust
Tags
1996, 2002, 2003, 50, 98, engine, ford, leak, main, oil, ranger, rear, seal, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
