Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-28-2002, 06:30 PM
MrRangerSir MrRangerSir is offline
Garage is empty, add now
MrRangerSir is starting off with a positive reputation.
The long and the short block of it all!
My 94 XLT, 2.3L (84k) has serious ring problems in the No. 1 & 2 cylinders. I'm finding it hard to locate someone to rebuild so now I'm looking at short and long block assemblies. What is a good price for short & long assemblies installed, and who to contact? I'm in the Oklahoma City area. :-staun
  #2 (permalink)
Old 06-03-2002, 10:12 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Post The long and the short block of it all!
OK,no one else bit. Is it truly worth putting $2k into a truck of this age? Check with Kragen/Schucks/NAPA/Pep Boys/Jasper and locals for a baseline price guide. Including labor, a replaced long block could run close to $2K with no problem. "hadda replace the hoses, cut when removed, Plug wires looked bad... old plugs were fouled out... Injectors looked bad.... Blah Blah..."
What would a good used engine cost? $600 from a junkyard is the high end for a 4-banger that would drop in. Figure 6-8 hours labor at going rate(ballpark $50/hr would be $300/400 labor). I know it would take me most of a day to R/R an engine. More labor less machine shop cost for a short block because of all the transfer/install work.
How long will you keep the truck? Can you do the work yourself? Do you like this truck REALLY that much?
Give it some thought...
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 06-05-2002, 06:48 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
__________________
ENCS(SS), (SW), USN RET (E-8)
Keweenaw Bay, MI
U.S. Navy (Submarine Service) 60-80
2010 Ford F-150 4WD Lariat Ext Cab
1999 Lincoln Town Car Ecec Series
1930 Model "A" Coupe
Tags
block, ford, install, lightning, price, short
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
