Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #61 (permalink)
Old 06-22-2008, 01:15 AM
adambomb's Avatar
adambomb is gaining momentum as a positive member of FTE.
nice pics. thanks for posting. i really like the quad pillar w/ blue lights. wish i would have taken photos when my truck was looking like yours. at least of i have mental pics. LOL
__________________
2005 6.0L F350 Lariat CCLB FX4
Dynomite Diesel 90hp Injectors
ARP Studs/Racing Gaskets
Spartan SCT X3
Banks Techni Cooler
FASS
AFE Stage I Intake
4" MBRP Turbo Back Exhaust
AutoMeter PhantomII Boost/Pyro/Trans Gauges
2.5" ICON Suspension*35" Xtreme AT's*18"KMC Monsters
Sponsored Links
To remove this ad, register today!
  #62 (permalink)
Old 06-22-2008, 07:39 AM
tex25025's Avatar
tex25025 has a good reputation on FTE.tex25025 has a good reputation on FTE.
Quote:
Originally Posted by gross30 View Post
I will have to set it up some more in the am. You are running Stage 1 injectors also Tex ?? Would I need to go that high with stock ?? Or is that the norm ?? All this new stuff, too much info.....lolol
60 is what ITP recommends and they did not distinguish between stock or modified injectors with determining fuel pressure. I do believe ATS' Regulated Return kit has you putting the pressure at 50 psi, so I guess if you don't want to bump it up as much as 60 til you get bigger sticks, then I guess you could do the ATS recommendation of 50. I just would make sure that you have it higher then the minimum setting of 45.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #63 (permalink)
Old 06-22-2008, 09:12 AM
gross30's Avatar
WORK IN PROGRESS
gross30 is starting off with a positive reputation.
Thanks Tex, I am going to adjust it this am, and figure out where the dashdaq II is going to hang.....
  #64 (permalink)
Old 06-24-2008, 02:57 PM
gross30's Avatar
WORK IN PROGRESS
Got the Dashdaq II wired in and working great. What a cool toy !!! Got the tunes from Eric at Innovative, and wow !! I am re-loving my truck again. I am saving all the parameters on the Dashdaq, to cross-ref the differences when, say the air filter gets dirty, oil change intervals etc. Quite the handy tool.....
  #65 (permalink)
Old 06-24-2008, 03:03 PM
tex25025's Avatar
Pixs? I am thinking about doing a custom dash deal for the digital gauge that Matt is using for his tunes when that comes out. Wood stained and all that, but could use any and all ideas as that is still in the air as to how I'm going to do that.
__________________
Fluidampner
Headstuds
FASS 150/180
  #66 (permalink)
Old 06-24-2008, 03:35 PM
gross30's Avatar
WORK IN PROGRESS
I will post some this afternoon. Getting a new front window in. Can't have all this new stuff with a cracked front window.....lolol
  #67 (permalink)
Old 06-24-2008, 06:10 PM
18vtx00's Avatar
18vtx00 is starting off with a positive reputation.
5,000lbs is light enough you can run an agressive race tune!! I tow my 31' camper which is 10,000lbs w/ this tune and seems fine. Stock heads & VGT. I only have replaced the sticks w/ '05 style and newer VGT since I was sick of cleaning it. 130K.
__________________
FORD MASTER DIESEL TECH
ASE MASTER, L1
HEAVY TRUCK-DIESEL, ELECTRONICS
'03 F350, CC, 8', 6.0L, LARIAT-SPARTAN SCT, 5" SILVERLINE COOL DUALS
'96 EXPLORER, 4DR, 5.0L, XLT
'05 SKI-DOO REV ADRENELINE
'86 FORD 555 LOADER/BACKHOE
'03 VTX1800C
  #68 (permalink)
Old 06-25-2008, 11:38 AM
gross30's Avatar
WORK IN PROGRESS
Here is a quick pic of the new Dashdaq II, I like it. Put on a set of black sidesteps w/gap guards and '08 mirrors also. I really like the look. They turned out good. Hooking the trailer up and heading north again, mirrors should be great. Time to go to work and pay for the toys....lolol
  #69 (permalink)
Old 06-26-2008, 05:45 PM
COLIN FAGBURGER's Avatar
COLIN FAGBURGER is starting off with a positive reputation.
Nice look with the mirrors, great job on the truck also. Keep up the good work...lol
  #70 (permalink)
Old 06-26-2008, 07:48 PM
tex25025's Avatar
Those mirrors really do look pretty good. I wasn't much fond of them in the beginning, but I think they are growing on me. I can't wait til I'm able to get that Dashdak and make that custom mounting pod for it in the cab.
__________________
Fluidampner
Headstuds
FASS 150/180
  #71 (permalink)
Old 07-01-2008, 06:36 AM
gross30's Avatar
WORK IN PROGRESS
I was able to tuck the Dashdaq just above the gauge pod on the drivers side. I didn't like it in the middle of the front window. It hides the data cable better also. Now all the gauges and dashdaq are all in one spot up the column. Also I couldn't read the dashdaq way over there with out the specs on.......
  #72 (permalink)
Old 07-01-2008, 08:44 PM
06PSD&79460 is starting off with a positive reputation.
mods
egr delete is a must.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
