Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-24-2008, 12:51 PM
thosfsull thosfsull is offline
thosfsull is starting off with a positive reputation.
Hydroxy Boost Addition on a Diesel E350?????
Found this today, personally I cannot believe it would get such craptastic MPG to begin with.
http://peswiki.com/index.php/Report..._Boost_Addition
I heard a lot of people bitching about Ultra Low Sulfer Diesel hamstringing mileage, but unless this dude had a untuned truck and/or carried a ton of equipment, I care to say HUH?
Before anyone asks, any 3/4 ton or higher diesel rig is never listed at the EPA fuel economy site. It should be able to at least match a modular 5.4L gasser e250.
Gas Mileage of 2001 Ford E250 Econoline 2WD
  #2 (permalink)
Old 05-25-2008, 07:46 PM
George D.'s Avatar
George D. George D. is offline
George D. is starting off with a positive reputation.
It probly was loaded.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo and 6.9L with said turbo on it, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
Nuge 2012!
  #3 (permalink)
Old 05-25-2008, 11:13 PM
fellro86's Avatar
fellro86 fellro86 is online now
fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE.
They never state what motor it was, it could have been a 460 to get the lower mileage like that...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #4 (permalink)
Old 05-25-2008, 11:34 PM
George D.'s Avatar
Just looked at it again and in the uper right corner under the picture of a a E350 it states it has a 7.3l powerstroke and that the van was empty but does have a ladder rack on top wich would catch wind.
__________________
Nuge 2012!
  #5 (permalink)
Old 05-26-2008, 12:27 AM
dchamberlain dchamberlain is online now
dchamberlain has a great reputation on FTE. dchamberlain has a great reputation on FTE. dchamberlain has a great reputation on FTE. dchamberlain has a great reputation on FTE.
He did his mileage calculations on "about 1/2 tank" and "about 1/4 tank". Totally meaningless.
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member:
To join the Oregon Chapter, click HERE
  #6 (permalink)
Old 05-26-2008, 01:07 AM
George D.'s Avatar
This is very ture.
__________________
Nuge 2012!
  #7 (permalink)
Old 05-26-2008, 01:16 AM
fellro86's Avatar
might as well just pull a guess out his arse, about as accurate... probably about what he did anyway.
__________________
Iowa Chapter leader
  #8 (permalink)
Old 05-26-2008, 02:39 AM
David85's Avatar
David85 David85 is online now
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
Has anyone even heard of a powerstroke of that era getting only 10 MPG? Not even the 6.4L is that bad.
true MPG calculations can only be made at the time of refueling, and even then, a single outliner of 20 MPG can happen, but that would probably have more to do with the shutoff of the station pump. We all know how much diesel can foam up.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #9 (permalink)
Old 08-02-2008, 10:52 PM
18vtx00's Avatar
18vtx00 18vtx00 is offline
18vtx00 is starting off with a positive reputation.
Unless there is something wrong w./ it..the ole 7.3L's were very economical but they had no emmission equipment.. funny how saving the evironment costs us a lot of mileage.
The more crap you put on an engine might flow cleaner exhaust, but uses more fuel to do it..does this even make sense?
7.3L 17-22MPG,6.0L 15-20MPG,6.4L 12-14MPG..see a pattern here?
__________________
FORD MASTER DIESEL TECH
ASE MASTER, L1
HEAVY TRUCK-DIESEL, ELECTRONICS
'03 F350, CC, 8', 6.0L, LARIAT-SPARTAN SCT, 5" SILVERLINE COOL DUALS
'96 EXPLORER, 4DR, 5.0L, XLT
'05 SKI-DOO REV ADRENELINE
'86 FORD 555 LOADER/BACKHOE
'03 VTX1800C
  #10 (permalink)
Old 04-28-2009, 11:51 AM
pritchet1 pritchet1 is offline
pritchet1 is starting off with a positive reputation.
The "Truck" is mine!
It is my truck. Yes, without the hydroxy system, it gets around 8 MPG. The van does not have an innercooler installed on it. Vehicles later had those included. This one did not. This is "worse case scenario". And yes, the van is the long-bed version.
Here is the latest report using the "Dry Cell" system - Hydroxy System for Diesel Vehicles – Solving Emission Contaminations
  #11 (permalink)
Old 04-29-2009, 04:14 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
And how much do you get with a hydroxy system?
  #12 (permalink)
Old 04-29-2009, 09:56 AM
How much do I get now?
It is really "to soon to tell" with the dry cell at the moment, but the fuel gauge indicates it is better than the wet cell technology. The wet cell technology was giving me over twice the mileage I was getting without it turned on.
The dry cell is much less maintenance than the wet cell. I was told last night by a person from DOE, that I need to state that wet cell hydroxy technology is obsolete.
  #13 (permalink)
Old 04-29-2009, 10:13 AM
jimandmandy jimandmandy is offline
jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE.
"Instead of only a 20% efficiency, we get closer to 50%, when using hydroxy to burn the hydrocarbons."
Here we go again. Its statements like that that peg my BS meter.
Jim
  #14 (permalink)
Old 04-29-2009, 10:32 AM
How old is the hydroxy technology?
It has been in existence since 1804. Read the updated info linked to the website listed at the top of this thread.
I appreciate the feedback from this forum regarding this vehicle.
The truck/van never ever gave very good mileage to my younger brother who owns the vehicle (it was used in roofing). He was surprised to find that the engine did not have an innercooler on it and his exclamation of; "No wonder it never performed very well!" said it all.
So we turned a sluggish trailer-puller into a better-performing machine.
With the hydroxy, there is more power, a quieter engine, better performance and much, much lower emissions. We did the emissions testing in Spokane WA. It got 4%, where 40% is passing. We did the tests of before and after. The results of those tests are posted at H2O Hybrid Pro. H2O HYBRID PRO
http://images.ford-trucks.com/forums...s2/mad0228.gif
  #15 (permalink)
Old 04-30-2009, 12:40 AM
George D.'s Avatar
I would have to say. How could hydrogen make it quieter? if anything it should make it louder as the hydrogen would burn faster and also theoreticaly cause faster more efficent burning off the fule wich would advance the timing. Does it seem wierd to any one els that this guys responses seem generic and out off no where?
__________________
Nuge 2012!
Tags
05 , 2008 , 2012 , 54 , 99 , cell , diesel , e250 , e350 , f250 , ford , fuel , hydro , hydrogen , hydroxy , make , mileage , technology , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
