Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-24-2008, 12:11 PM
TheNomad's Avatar
TheNomad is starting off with a positive reputation.
Unhappy 302 valve chatter
Hello every one.
I'm getting real bad bad chatter from my valve train I'm not sure if its the rockers or some thing worse but I don't know how to check to see whats making the noise, the rockers are none adjustable so i'm not sure how to check for lash
I checked too see if any thing was lose and nothing was I was able to turn one push rod by hand.
I know its next to impossible for you guys to know what it might be but any ideas or hint's would awesome.
__________________
79 F-150 Ranger 5.0.
F-150 Ranger 7.5
" I will stand with the Muslims should the political winds change" Barack Hussein Obama" NoBama
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-24-2008, 03:02 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
How do you know it's valve clatter? When are you hearing it.. under what conditions?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 05-24-2008, 03:57 PM
TheNomad's Avatar
Quote:
When it warms up and is sitting at idle or driving from the right side of the engine I get this really nasty chat chat chat and fallows the rpm of the engine.
it sounds like pure metal on metal. I look at the rockers and springs and did not see any ware or shine..
But I get skips in timing or back fires and vacuum hangs around 15 at idle.
I'm thinking about taking some video of it and posting it as soon as I can find out how to do so
__________________
F-150 Ranger 7.5
  #4 (permalink)
Old 05-24-2008, 10:21 PM
Conanski's Avatar
I'd say it's an exhaust leak.. probably a cracked manifold. You probably won't be able to see the cracks but the manifold will come off in pieces after you remove the bolts.
__________________
Paul O
  #5 (permalink)
Old 05-24-2008, 11:41 PM
TheNomad's Avatar
So you mean one of my headers are broken... Wow that sucks. Well its a heck of a lot better then the valve train =)
__________________
F-150 Ranger 7.5
  #6 (permalink)
Old 05-26-2008, 07:25 PM
TheNomad's Avatar
Sorry Doc But thats not it.
I fear its some thing internal. every one is going to think I'm crazy for doing this, I warmed the engine until the noise was really bad then popped off the valve cover and Ow did it get louder sounds like the engine is playing the spoons.
Oh I took off the manifold and checked every thing was fine.
The push rods are oiling great nothing seems lose all bolts are tight and torqued.
I would have been better off getting a junk yard engine then getting it from the place I got this paper weight.
__________________
F-150 Ranger 7.5
  #7 (permalink)
Old 05-27-2008, 01:36 PM
Conanski's Avatar
Have you got a real oil pressure gauge to put on this thing? The dash gauge is just a switch and only indicates that you have 6psi oil pressure or more. A good motor will have about 15psi at idle and should build at least 10psi more per 1000rpm increase.
__________________
Paul O
  #8 (permalink)
Old 05-27-2008, 02:04 PM
TheNomad's Avatar
No I just have the dash gauge.
Well ever since the "New" engine was broke in my Oil gauge reads on the high side once its warmed up...
__________________
F-150 Ranger 7.5
  #9 (permalink)
Old 05-27-2008, 04:14 PM
BaronVonAutomatc is starting off with a positive reputation.
How easily can you turn the pushrods? There should be enough preload on the lifters that there's some resistance when you try to turn them.
Does it have rail or pedestal rockers?
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
1982 F250 4x4 w/302 & C6
  #10 (permalink)
Old 05-27-2008, 04:21 PM
TheNomad's Avatar
I can turn them but there is some resistance very very little. And yes the rockers are railed.
__________________
F-150 Ranger 7.5
  #11 (permalink)
Old 05-27-2008, 06:05 PM
The usual way to set pre-load is to tighten the lock nut until you start to feel resistance when turning the pushrod, then tighten another 1/2-3/4 turn.
__________________
  #12 (permalink)
Old 05-27-2008, 07:54 PM
TheNomad's Avatar
I tried that and the nuts are all very very tight all ready..
__________________
F-150 Ranger 7.5
  #13 (permalink)
Old 05-27-2008, 10:03 PM
When you say skips in timing, what does that mean? Like it's missing? Or the timing is jumping around?
Backfires (through the carb) and low vacuum are symptoms of retarded timing. Try advancing it a couple of degrees at a time until you get it above 20".
As far as the noise, if the rockers are already super tight it might be your rocker tips are worn or the valve tips were ground. The engine is a recent rebuild, right?
__________________
  #14 (permalink)
Old 05-27-2008, 11:21 PM
rikard is starting off with a positive reputation.
Many years ago we had rebuilt a 302 and got the same clatter. It turned out to be three bent push rods.
As stated by others make sure oil system and timing are good.
good luck
rikard
__________________
Present-1995 Black F150 SC XLT 300 5 Spd
Past-1994 Red F150 SB XL 300 5 Spd
1983 Red F150 SB XL 302 AOD
1962 USPS 2.5 ton stepvan converted camper
223 3 speed DRW
1956 Red F100 Ma Bell uility bed 223 3 Spd
  #15 (permalink)
Old 05-28-2008, 12:28 PM
TheNomad's Avatar
No I would say the timing is fine. O
ther then my truck all ways being a little low on the vac side of things.
It sits around 14/15 area.
Before I installed this HEI I could not advance the timing over 9 or I started getting pings, and also had very low vac around 9, and this was after the said rebuild of the engine. But since I installed this HEI I have been able to advance the time lot to get more vac at the carb.
__________________
F-150 Ranger 7.5
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
