Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-13-2002, 10:37 AM
99Guy 99Guy is offline
Garage is empty, add now
99Guy is starting off with a positive reputation.
Solving a strange knocking from Heater Hoses
I know it sounds weird. I recently started noticing a strange slight knocking sound when coasting in my 99 Ranger (with the 2.5L 4-banger and 5-speed manual). I could actually feel the knock slightly in the steering wheel. After careful listening I realized that the knock is always present but is usually drowned out by my radio and racous engine note. The knock seemes to occur more over rough terrain, as if something was loose. Well, vibrations can travel, so I popped the hood and started wiggling everything. I found that the heater hoses that run from the front of the engine down the left side to the heater box have quite a bit of slack. In the middle of these hoses is a plastic junction which was banging into the AC condenser (a black metal cylinder) leaving a telltale scuff on the condenser. I secured the heater hoses to the intake hose with a Long (1 ft) twisty tie and viola, the knock is gone. Hope this helps someone.
  #2 (permalink)
Old 11-13-2002, 11:13 PM
mikeeep mikeeep is offline
mikeeep is starting off with a positive reputation.
Tags
engine, ford, heater, hose, knocking, strange
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
