Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-24-2008, 12:06 AM
lazyscholar is starting off with a positive reputation.
6.9 high pressure turbos
Hello everyone my friend is about to get a 85 6.9 and he wants to add some performance to it. One of the many the many things he wants to do is add twin holset turbos. I think that would be about 60 psi if he put on a head stud kit from dps would it work?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-24-2008, 12:28 AM
DieselRunner is starting off with a positive reputation.
it would work on a powerstroke, something that can handle that much boost.
but on these idi's... first ive never heard of a twin turbo set up on an idi.
second with the higher compression on them, 60 psi would be somewhere near imposible.
the highest boost numbers ive seen and a 6.9 or 7.3 idi are mid 20's (daves)
and thats after extensive work to his 6.9.
in my opinion if your friend wants a performance diesel, get something that would be easier to get that much more power out of.
__________________
1991 F-250 XL EXT Cab 7.3L turbo diesel. ZF 5 speed 2WD 3.55
  #3 (permalink)
Old 05-24-2008, 12:31 AM
stevilknevil's Avatar
stevilknevil is starting off with a positive reputation.
sounds like a good way to make scrap to me
__________________
'79 f-250 7.3 idi,4x4,4.56 gears,4-speed,some rust,lots of fun
  #4 (permalink)
Old 05-24-2008, 12:34 AM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Simply fitting the turbos (and related piping) would be a challenge. If you drop the compression ratio, you could probably run some high numbers like that, but to drop that much compression will cause cold start and serious economy issues.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #5 (permalink)
Old 05-24-2008, 01:05 AM
i told him that that was probably too much psi for that high of a compression, not to mentioned they were never designed for a turbo. However i have a 93 7.3 and was considering a single holset, I'm not as ambitous, i think that with a head stud kit it might work but i dont want to tear it up ill probably have the moter out wwhen i do this but I'm not doing a rebuild, yet.
  #6 (permalink)
Old 05-24-2008, 02:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Milled pistons to lower compression and head studs will let you run about 30 PSI boost.
To go over that you are looking a O ringed heads and block as well as a couple other mods.
With milled pistons and head studs, at 25 PSI boost my effective compression ratio is higher than a Power Stroke running 30 PSI.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #7 (permalink)
Old 05-24-2008, 07:41 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Ok first off wich holsets are you talking about? they make them in many different verieties and alot of them would not put out much boost with the exaust flow of theres engines. 60psi on the stock 21.5 to 1 cr would be an insanly high efective compresion ratio. But If you guys like the trucks, have money and would like to make a preformace truck it is definatly possible. Get head studs heads with built in firerings milled down pistons, and a custom IP and injectors. I'd also replace the rods and use ARP rod bolts if availible and have the governor set at 4000 rpm with some heavy duty valve springs.
Twins are possible I've seen a powerstroke with three turbos you could definately fit two on one of these but a single turbo could also be made to put out high boost #.
So how fast can you aford to go?
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #8 (permalink)
Old 05-24-2008, 08:17 PM
22.5 to 1 base compression ratio with 60 PSI boost would have an effective compression ratio of 114.33 to 1.
A Power Stroke engine with an 18 to 1 compression ratio would only be 91.46 to 1 with 60 PSI boost.
Right now my compression ratio is 20.25 to 1, with 25 PSI boost my effective compression ratio is 54.68 to 1.
At 30 PSI that increases my effective compression ratio to 61.57 to 1.
A Power Stroke running 30 PSI has an effective compression ratio of 54.73 to 1.
There is a limit as to how low you can go with the compression ratio of an IDI, starting will be a big issue at 18 to 1 or lower.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #9 (permalink)
Old 05-27-2008, 04:12 AM
RLDSL is starting off with a positive reputation.
I doubt it would hold together long at 60 psi, even with studs, and as far as studs, go with the ARP head studs, There has been a rash of failures lately on the DPS head studs and the guy has yet to respond to a single one of the people who spent hundreds of their hard earned dollars with him on his defective studs, He's left them all holding the bag.
There is also an ARP option for 7.3 head studs .
__________________
'92 F350 CC Dually, 7.3 Ats Turbo, 4" exhaust, Custom Rodney Red aluminum radiator, Zf5, 4.10 ,Western Hauler bed, Air seat, Bilsteins.
  #10 (permalink)
Old 05-27-2008, 09:12 PM
do i need milled pistons for 30 psi, i was really just going to put the studs on. Thanks
  #11 (permalink)
Old 05-27-2008, 09:36 PM
George D.'s Avatar
Yes you do might be able to get away with studs and heads with built in firerings or an oringed block.
__________________
  #12 (permalink)
Old 05-27-2008, 10:36 PM
You will never make it to 30 PSI with just head studs and stock pistons very many times.
And you will also blow the valley pan at the intake to head junction.
23 PSI is all that gasket can take in stock form.
Been there done that before.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #13 (permalink)
Old 05-27-2008, 11:10 PM
i just started another thread about building it up. What would you recomend Dave?
  #14 (permalink)
Old 05-27-2008, 11:58 PM
Start with a good 6.9 block and build it.
7.3 sleeves, what a bad joke.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #15 (permalink)
Old 05-28-2008, 02:28 AM
dave how mush horsepower u got?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
