2.3L hsc topaz 89' stumbling..
Old 06-08-2002, 06:28 PM
Mauser8mm's Avatar
Mauser8mm
Mauser8mm is offline
Old 11-28-2002, 10:10 PM
crash104936221's Avatar
crash104936221
crash104936221 is offline
hey i know that this isnt a car faourm but hey its a ford too
the car seems to stumble when i accelerate between the 2000-3000 rpm range
what would cause this problem
fuel isnt the problem cuze it starts and idles well and reves well under and over the stumble
thanks for the help all
Jc
Old 12-02-2002, 07:33 AM
tomw's Avatar
tomw
tomw is offline
Plug wires breaking down under load.
Fuel filter-flows enough at low load conditions, not enough for power.
EGR valve sticking.
Sparking Plugs with bad or wide gap breaking down under load.
TPS sensor bad fooling the ECM into thinking you closed throttle.
MAP sensor out to lunch intermittently, leaning or enrichening mix.
Pull the codes, and see what you find before spending $$. The TPS can cause the trans to drop out of OD if yours has an AXOD.
Again, pull the codes first.
tom
ps. you could get the 2.5 out of a Taurus, and have a mild sleeper...
that'd be fun, lots of torque, too.
Old 12-03-2002, 01:29 AM
crash104936221
its just my beater (drive it in the feild and backroad) so an engine swap not feesable
is there a way to check the tps for corect funtion as i checked the wires and rotor fuel plugs
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 2.3L hsc topaz 89' stumbling..
