Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-27-2008, 11:29 AM
VaSheriff is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Daviddc114 View Post
i dont know if you have an aftermarket alarm or remote starter in there but i know they have to access the ignition wires so this is where your problem could lie. also about the alternator, if you have a wire shoerting out this could draw your battery, if you put a mulitmeter on the battery and give the truck gas it should read about 13 - 14 volts (while the truck is at about 1500 - 2000 rpm) if it stays at 12 volts than your alternator is shot.
I do not have aftermarket add ons of any type.
And the multimeter is reading a constant 12.
While your suggestions are appreciated, I am going to let Ford do the work, I don't feel comfortable poking around in the steering column, or poking around with an electrical issue. They are going to fix the electrical short first, then take a look at the charging issue after that..... tomorrow morning.
At this point I am simply keeping a dead fuse in the circuit and doing without the gauges.
__________________
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 05-29-2008, 01:25 PM
Well, the final verdict is in.
Overdrive relay module was shorting out.
Replacing it straightened out everything else.
Parts and labor -- $331.
__________________
  #18 (permalink)
Old 05-29-2008, 09:10 PM
Paul T is starting off with a positive reputation.
Ouch!!!
  #19 (permalink)
Old 05-29-2008, 09:51 PM
Actually Paul, I was quite pleased. Pleased to learn I didn't have several things going wrong at the same time. A new alternator alone, if needed, would have been about $300.
Anyhow the module was $58+ and the labor was $237. And some silly $33 shop fee.
I was sorta ticked because they charged me for 3 10 amp fuses, $2.25, I left a whole box full of hundreds of fuses sitting in the floor for them to use for test purposes. Must have been 35 10 amp fuses in the box.
I drove the Excursion this afternoon, and this evening. They appear to have found the sole problem, and fixed it right.
__________________
  #20 (permalink)
Old 05-29-2008, 10:36 PM
BIG BOI's Avatar
BIG BOI is starting off with a positive reputation.
thats crazy!!! thats why i do all my work myself, i have a manual and a cd with detailed pictures. wow, i would have lost my mind and Ford is wondering why they are loosing so many customers to foreign car makers. I feel sorry for the average person who cannot afford to take there truck to the dealership to be hosed!!
  #21 (permalink)
Old 05-29-2008, 11:24 PM
western star is starting off with a positive reputation.
Glad you got it fixed VA. Nothing worse than a bad relay is much better news than a worse case senario
__________________
No replacement for displacement
  #22 (permalink)
Old 05-30-2008, 08:48 AM
Quote:
In the image below you can see the overdrive cancel switch they replaced. Top center of image under the #5.
My biggest problem would have been diagnosing exactly what was causing all of my problems. My Excursion wasn't throwing any codes out with OBD.
__________________
  #23 (permalink)
Old 05-30-2008, 12:11 PM
Daviddc114's Avatar
Daviddc114 is starting off with a positive reputation.
Hey VA, nice diagram, where did you get it??
anytime you need any i got them of the ENTIRE truck..
__________________
David Carbone, Jr.
2000 EXCURSION Limited 4x4 6.8 Litre V-10
  #24 (permalink)
Old 05-30-2008, 12:59 PM
I stole it from some guy on the Internet.
Thanks!
__________________
  #25 (permalink)
Old 05-31-2008, 07:22 PM
moosed is starting off with a positive reputation.
Don't know if this is the same issue but: I recently received a recall notice for safety related overdrive overheating issue, everything was replaced(don't know exactly what parts or where)with no cost to the owner(me). I have a 2003 V10 Limited.
Tony
  #26 (permalink)
Old 05-31-2008, 10:32 PM
Quote:
Tony
Very interesting. Wish I could find out more about it. Anybody????
I can add one more thing here though. Thursday night and Friday night I let my daughter drive me around in the Excursion. She's 15, just got her learner's permit, and needs the practice. Everything seemed fine. Tonight....... I drove myself around, just got home. It's amazing how much better the Excursion is now running. The engine is running better. The transmission is shifting better. The radio/CD has stopped "initializing", I thought it was going bad and wasn't related to the other problems. I did not realize how bad it was starting to run because this problem(s) started off slow and gained momentum over the last several weeks, to the point of actually breaking down.
__________________
  #27 (permalink)
Old 06-13-2008, 09:29 PM
I was talking to a local tow truck driver tonight. He knew of my specific problems because he is the one who loaned me several diagnostic tools.
Anyhow, he told me he towed an Excursion that had totally burned up earlier this week. The Excursion driver reported the fire starting as smoke coming from the steering column.
I guess it's safe to say that if any of you guys and girls see smoke coming from your steering column, turn that sucker off and take the key out of the ignition as quick as you safely can.
__________________
  #28 (permalink)
Old 06-13-2008, 10:18 PM
aortizexcursion's Avatar
aortizexcursion is starting off with a positive reputation.
Tony
Yours sounds like the cruise control recall, you should get it repaired ASAP.
Heres some info on the recall.
  #29 (permalink)
Old 06-14-2008, 08:44 PM
cbradford's Avatar
cbradford is starting off with a positive reputation.
I would look for the arc marks and find the bare wire with black/ burnt insulation
__________________
Chris
05 Excursion Limited V10
4:30(C3) Limited Slip
61K
Mods:Front Cyro Power Slot Rotors & Hawk LTS Pads, Moog ball joints, Bilstein Shocks
01 Expy EB
5.4
3.55 (H9) Limited Slip
45K
Stock
2006 27' Outback T.T. 7000lbs-loaded
  #30 (permalink)
Old 06-14-2008, 10:33 PM
Quote:
In my Excursion, I let the Ford dealer repair it. It is my understaning they replaced the switch that was shorting out and any/all wires that were affected by it. They must have done a good job because everything has been fine since the repairs. It's actually running better than I ever recall it running. This "short" must have been affecting a lot of various components.... kinda like a cancer spreading throughout the entire Excursion.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
