Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-08-2002, 06:28 PM
Mauser8mm Mauser8mm is offline
Garage is empty, add now
Mauser8mm is starting off with a positive reputation.
2.3L hsc topaz 89' stumbling..
__________________
Fun:1979 F-150 4x4 351M C-6 NP205
Commuter:2001 Ranger XL
  #2 (permalink)
Old 11-28-2002, 10:10 PM
crash104936221 crash104936221 is offline
crash104936221 is starting off with a positive reputation.
hey i know that this isnt a car faourm but hey its a ford too
the car seems to stumble when i accelerate between the 2000-3000 rpm range
what would cause this problem
fuel isnt the problem cuze it starts and idles well and reves well under and over the stumble
thanks for the help all
Jc
__________________
RHC Member #102
96' F150 XL I6 5spd 2.73's Teal
85' F150 XL I6 4spd 3.55's Dark Charcoal
  #3 (permalink)
Old 12-02-2002, 07:33 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Plug wires breaking down under load.
Fuel filter-flows enough at low load conditions, not enough for power.
EGR valve sticking.
Sparking Plugs with bad or wide gap breaking down under load.
TPS sensor bad fooling the ECM into thinking you closed throttle.
MAP sensor out to lunch intermittently, leaning or enrichening mix.
Pull the codes, and see what you find before spending $$. The TPS can cause the trans to drop out of OD if yours has an AXOD.
Again, pull the codes first.
tom
ps. you could get the 2.5 out of a Taurus, and have a mild sleeper...
that'd be fun, lots of torque, too.
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #4 (permalink)
Old 12-03-2002, 01:29 AM
its just my beater (drive it in the feild and backroad) so an engine swap not feesable
is there a way to check the tps for corect funtion as i checked the wires and rotor fuel plugs
__________________
RHC Member #102
Tags
2001, 23, 23l, 3000rpm, 89, catalog, de, ford, hsc, motor, ranger, stumbles, topaz, videos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
