Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-23-2008, 09:49 PM
NicksF250 NicksF250 is offline
NicksF250 is starting off with a positive reputation.
87 fuel system electrical
Carb not receiving fuel on start up, fuse # 15 & 18 are ok, I am not receiving power to the red/yellow wire at the fuel selector switch. Just before the switch at the wire plug there is a hot wire on the harness side but nothing on the switch side (blank), I ran a lead to the red/yellow wire from that hot wire and the truck starts and runs. The truck continues to run when the wire is removed. How does the red/yellow wire get its power? My Haynes book shows a "fuel pump relay" where is this located, could this be the problem or can it be my ignition switch?
Nick
  #2 (permalink)
Old 05-24-2008, 06:44 AM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
Hopfully someone will know the answer to your problem.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
