Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-07-2002, 12:22 AM
pancake's Avatar
pancake pancake is offline
1999 Ford F-150
pancake is starting off with a positive reputation.
ford tempo excessive oil consumption 2.3
well it is pretty well covered in the topic....
92 tempo miles unkown but is an efi 2.3 and goes through oil like water but no visible massive leaks i get the feeling it is rings and it is passing the piston and burning it off bc it has a smell to the exaust but it is not what i call an oil smell it seems more like it is running rich....
any common problems with these engines
__________________
THE NEW TO ME MOBILE->99 f150 suprcab 4.6 auto 4x4 75k...
  #2 (permalink)
Old 12-07-2002, 01:34 PM
mike_long mike_long is offline
Garage is empty, add now
mike_long is starting off with a positive reputation.
  #3 (permalink)
Old 10-09-2003, 06:52 PM
carpe_diem carpe_diem is offline
carpe_diem is starting off with a positive reputation.
TTT
I think I have the same thing except mine is 87 Topaz.
106K miles.
  #4 (permalink)
Old 10-10-2003, 08:10 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
rings or valve stem seals. PCV stuck or gummed up. Low viscosity oil. Leaks. Being vaporized under the piston top due to high heat.
If you don't see blue smoke, you still can be burning oil. My dad (B29 engine engineer) said that if you see blue smoke, it's REALLY burning oil.
see other post.. by carpe_diem
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #5 (permalink)
Old 11-04-2003, 01:47 PM
As I already posted ... mine is burning oil too. It appears I get less than 1,000 miles per quart, probably 800. I will try switching to 20-50.
Tags
23, 93, 94, burning, burns, consumption, escape, excessiive, ford, loss, oil, sho, tempo, topaz, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
