Clutch - Ford Truck Enthusiasts Forums
Clutch
Old 10-20-2002, 02:51 AM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
Clutch
Old 12-07-2002, 02:34 PM
mike_long mike_long is offline
mike_long is starting off with a positive reputation.
Clutch
I have a Ford Ranger XLT and the ckutch went out on me. I cjecked the resevoir and it was empty. I refilled it and did the bleeding procedure and it still does not work. How long do you have to let the fluid run through to get it right? I let it run until I saw no bubbles in the plastic hose. About a minute or two. Closed the velve and got a friend to push the pedal to the floor and hold it. I released the valve again until the flow stopped and then closed it. The pedal is still mushy. I saw on another site that you need to let the line bleed for about 30 minutes. That would go through a LOT of fluid wouldn't it?
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
