351W powersteering pump bracket
on
Here's my 2 cents, I'm going to say the brackets are similar, but I bet they are not identical.
I'm trying to install PS on our Ranger, I sourced all the parts fom a Mustang, and you would think they would fit, but no, there's not enough clearance between the pump and PS box on the truck. Same motors in both vehicles BTW.
I also bolted all the 302 serpentine brackets on my 5.8 when I swapped them, but somehow I ended up with a belt misallignment between the crank pulley and the accessories. The solution was to go get the accessory brackets for the 5.8 truck motor, and then everything lined up beautifully.
Some 1978's use two brackets, some only have one. With two brackets, the P/S pump adjusting bracket is the same 302/351W, the mounting bracket isn't the same.
Some 1979's also use two brackets, some use one. The same rules apply here, too.
Jacks 65
19
08-10-2016 09:30 PM
dsmit412
06-29-2016 10:28 PM
johnson.jeff.a
12-25-2015 11:11 PM
rickdavis81
07-03-2014 07:46 AM
