Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-22-2008, 10:40 PM
erictw is starting off with a positive reputation.
velvac mirrors
Hi, my box van (and apparently quite a few others) has the velvac towing mirrors, one of which is not staying in position. Can this be adjusted? It is a '98 E350 former ryder truck.
thanks
Eric
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-26-2008, 04:35 PM
MuddyAxles has a good reputation on FTE.MuddyAxles has a good reputation on FTE.
Not sure
What you mean by "velvac" mirrors, but I'm thinking they're the old style truck-like mirrors mounted on a tubular frame with a stamped steel backing/holder for the glass. If that is the style, I'm quite familiar with them; they've been used for years.
So if that is the style, they can be adjusted if the ball and socket are not rusted up. On the back of the mirror there are three screws holding a collar that is inside between the glass and the backing putting tension on the ball. I have had some luck tightening those screws to cause enough increased friction to hold the mirror in place. If not, I have seen replacements in parts stores and truck stops for sale.
  #3 (permalink)
Old 05-26-2008, 04:42 PM
Not sure
Does your mirror look like this? It is similar to that I explained and I think you could try the same with the screws either side of the ball stud. Again, I have seen these for sale for not a lot of money and pretty easy to bolt on.
  #4 (permalink)
Old 05-26-2008, 06:17 PM
mirrors
thanks! No, mine are the ones between those and the ones used now. They are a single tube mounting in the corner 0f the window, like in the current ones. If you check ebay under velvac they'll come up, at huge prices. I am sure that the mechanics are similar, I'll disassemble them next chance I get and see what's up.
Eric
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
