Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-01-2001, 10:37 AM
mtflat mtflat is offline
Garage is empty, add now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Flathead on the road!
I just completed a cross-country jaunt in my '48 pickup with the flathead V8. Trip went from nw Montana to eastern Ohio by way of Denver, Wichita and Kalamazoo, MI. The return trip was a little more direct. Total miles logged was 5,391 and averaged 15.7 mpg eastbound and 13.5 westbound (headwind). Used a quart of oil every 350 miles or so, and I dumped in a can of lead substitute every other tank.
Only significant problem was loss of one waterpump in central IL requiring overnight air shipment of a new one from Sacramento Vintage Ford.
Smoothest running engine I've ever driven across this great country.
Get those flatheads out and drive them!!
  #2 (permalink)
Old 11-02-2001, 02:55 PM
saxtonj's Avatar
saxtonj saxtonj is offline
saxtonj is starting off with a positive reputation.
I am curious.... what gear set ratio do you have? That's decent gas milage. Not too good oil milage. saxtonj@flashmail.com
Thanks,
James
  #3 (permalink)
Old 11-02-2001, 06:07 PM
Hi James,
Rear gears are 3.50. I swapped in a 9" rear before the trip - lets me run about 62 mph @ 2400. Just have to accept the fact that everybody will pass you......on the oil, I can only say that it doesn't burn blue smoke and it leaks a bit from the underside.
Tim
  #4 (permalink)
Old 11-05-2001, 10:05 AM
saxtonj's Avatar
I am running the original 3.73s in my truck... I'm glad to hear the MPG was as high as it was. The old train of thought when the flatheads were still new was "If it ain't burning oil, it ain't lubricating the engine like it should".
James
  #5 (permalink)
Old 12-29-2001, 11:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
