05-23-2008, 11:49 AM
IIRC, the OE 2bbl was ~350cfm. So if your engine is near stock that should work fine. Maybe a little choked off at higher RPM, but better low end and throttle response. Or Holley and Demon make electric choke 500 cfm vacuum secondary 2bbl carbs. With some hop-up, headers, duals, etc. that would be the way to go. Vacuum secondary with an auto tranny or mechanical for manual.
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
1982 F250 4x4 w/302 & C6
