should be, they had dozens signed on until the switched locations.Found out what broke drivers wheel bearing took a crap and then spun on the spindle and fried it to. So , Ford does have them anymore.
I imagine Ford should still carry the parts. Wrecker should also have something. A few in Kamloops from what I remember. If you can get the numbers off the bearings it may be cheaper to get them from a bearing outfit.
$20 at Pick n Pull, got a door for Wifes car and a new air box top piece for $60 extra . Turns out the pass side spindle is still good but the outer nut was loose!!! And the wheel and torington bearings were both toast. Probably be $140 ish for parts and $150 - $200 for the labour.
