Heads Heads
Old 12-26-2001, 01:33 PM
STEVE1103's Avatar
STEVE1103
STEVE1103 is offline
Heads Heads
Does anyone know if you can powder coat a set of flatheads, and is it a good idea? Have a Merc and was told the 53 heads make good power and are very reliable.
Old 12-27-2001, 07:37 PM
toyshop's Avatar
toyshop
toyshop is offline
Heads Heads
I would presume that you can powder Coat anything that can conduct a magnetic charge. I don't know why it wouldn't work, but would avoid coating the gasket surfaces. I don't believe it would cause any problems. Not my experience, but what i know about PC'ing. Check with others before using this as gospel.... Good luck.
Old 01-02-2002, 08:48 PM
tcw's Avatar
tcw
tcw is offline
Heads Heads
this is an interesting idea. how much heat can powder coating take?
Old 01-04-2002, 09:49 PM
DirtySideDown's Avatar
DirtySideDown
DirtySideDown is offline
Heads Heads
One of the Exhaust Header coatings might be a better choice. I can see where it could get expensive as prep time would, I think, be very critical so a not to coat unwanted area's
Old 01-10-2002, 04:03 AM
46fordtruck's Avatar
46fordtruck
46fordtruck is offline
Heads Heads
Just remember this: Powder coating may reduce the ability of the heads to dissipate heat, and exhaust coatings may do the same thing. Just something to think about.
Old 01-10-2002, 10:39 AM
mtflat's Avatar
mtflat
mtflat is offline
Heads Heads
The other half of your question was about the heads. The 52-53 Merc heads (EAC) on a merc motor produce about the same CR as the 8BA heads on Ford motors 49-51.
The smallest combustion area was produced in the 52-53 Ford heads (EAB) and therefore produce the highest compression ratio available with stock heads when used on either motor.
Old 01-22-2002, 11:05 PM
jml's Avatar
jml
jml is offline
Heads Heads
stagecall
06-06-2016 01:14 PM
1950FordF1
WTB - Parts & other
12-26-2014 12:52 PM
Quick Reply: Heads Heads
