Adjusting Washer Spray Nozzle? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-22-2008, 03:53 PM
Munkey's Avatar
Munkey Munkey is offline
Munkey is gaining momentum as a positive member of FTE.
Howdy,
Is there anyway to adjust the windshield sprayer nozzle? My drivers side nozzle is now spraying right at the bottom of the windshield.
I used to adjust other nozzles with a safety pin in the nozzle hole, but mine is a different style where the actual hole is not visible.
Any help?
Old 05-22-2008, 07:18 PM
chuck06250 chuck06250 is offline
chuck06250 is starting off with a positive reputation.
Have you tried cleaning it?
Try a set of tip cleaners used for a torch tip.
Old 05-22-2008, 08:38 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I use an air compressor with around 20 PSI to clean mine. There's an inline connector in the rubber hose under the hood up close to the windshield on the passenger side. Just unplug the hose and shoot some air through it.
Old 05-23-2008, 08:50 AM
motown's Avatar
motown motown is offline
motown is starting off with a positive reputation.
I had one do the same thing, I just replaced it. I tried adjusting it, but it has nway to adjust the direction of the spray. And it's quite easy to swap out. the price is a killer though, I got mine from Direct Ford parts for around $6.
Old 11-06-2010, 02:04 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Quote:
whats the part number i think i need one.
Windshield washer nozzles grayf250 1999 to 2016 Super Duty 14 03-13-2015 04:26 PM
Windshield Washer Adjustment - 2003 E250 Done_Deal 1968-2013 Full Size Vans 5 04-07-2014 08:53 AM
Washer Nozzle Adlustment Super Mech 1987 - 1996 F150 & Larger F-Series Trucks 3 01-16-2014 02:54 PM
Low Water Pressure on Windshield Washer? johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 11 01-15-2014 11:59 PM
Windshield washer nozzle swheeler Excursion - King of SUVs 3 03-19-2012 12:35 PM
Tags
08, 2008, adjust, escape, f150, f350, f450, ford, nozzle, nozzles, spray, sprayer, washer, windshield, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
