Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-22-2008, 03:30 PM
Bulldawg1081 is starting off with a positive reputation.
please help!!!!!!
hey guys i have a question about an '86 f-150 ive just aquired..i wanted this truck because its the old body style which is my favorite but has the later model fuel injection..HERES THE PROBLEM..the thing runs wonderful but i just found out that it has alot of blow by and some rattling in the bottom end when you first start it up,i understand this '86 is an oddball, something about it having flat top pistons and some other differences that no other years had...i have the option to get an '82 model 302 thats pretty fresh for just a couple of hundred bucks to put into this truck but would it be worth it or would i just be better off overhauling this one?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-22-2008, 04:01 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Yes, '86 was an oddball year, but I don't think this truck would have the fabled 5.0HO motor, the one with the flat tops and E6 heads. It's far more likely this motor has dished pistons and E5 heads. Look for a capital letter stamped into the head at one of the top corners near the valve cover, the letter R signifies '85, S = '86, T = '87.
The '82 motor would swap in but will probably need a cam change, and you don't want the stock EFI cam either.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 05-22-2008, 07:04 PM
what cam would you recommend for this '86 engine if i just overhaul it? i might as well just over haul this one instead of changing cams in an old engine,atleast ill know what i have...this is what i want to do with this truck....cruise,be some what peppy, and try to get the best mileage i can out of a 302,and occasionally pull a 20 ft bumper pull travel trailer
  #4 (permalink)
Old 05-22-2008, 10:29 PM
Conanski's Avatar
The Comp cams 31-255-5 is the one I suggest a lot, it's a short duration high lift cam that will make the most of the stock heads and valvetrain, and it's SD EFI friendly. Combine it with a set of longtubes and you'll have a significantly stronger motor. If it does turn out you have the E6 heads, substitute a set of E7 heads on the motor, and rebuild the bottom end with flat top pistons with valve reliefs, that wil put CR a touch over 9:1.. about 1/2 point better than the stock motor and the same as all the later motors.
__________________
Paul O
  #5 (permalink)
Old 05-23-2008, 03:07 AM
Beanscoot is starting off with a positive reputation.
Hi Paul,
Very interesting that there is, "a capital letter stamped into the head at one of the top corners near the valve cover, the letter R signifies '85, S = '86, T = '87".
I know the T is on (all?) E7TE heads, but what casting numbers are on these others?
Is the 85 E5TE, and the 86 E6SE or E6TE? Did this lettering system only start in 85?
With the difficulty of identifying installed Ford heads this info could be very useful to a lot of us.
  #6 (permalink)
Old 05-23-2008, 08:36 AM
Conanski's Avatar
I have a pair of all 3 of those heads in the shop and noticed this. It doesn't appear the capital letter thing is consistent for all years... though I have not seen a lot of newer or older castings. The first 2 letters of the primary casting number signifies the year the casting was first molded, this is consistent for all years and has never changed. E5 is '85, E6 is 86, and so on.
__________________
Paul O
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
