Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-19-2001, 06:19 PM
chenders chenders is offline
Garage is empty, add now
chenders is starting off with a positive reputation.
flathead question
I have a few flatheads v8s, 48-53. One came with the crossover in the front and manifolds with provisions for the crossover and one output for a single exhaust. The other had manifolds that has only one output, so I put a dual exhaust on it. Which is the original set up, and how can I get another set of the manifolds with the one output?
Thanks in advance for your many, many responses,
Chris
  #2 (permalink)
Old 08-26-2001, 08:46 AM
Wired Wired is offline
Wired is starting off with a positive reputation.
flathead question
The make of the vehicle that the manifolds came off of is needed to figure this out as a larger truck used the crossover in front or vice versa ( I could find out from a mechanic here in Canada and get back to you tomorrow )
  #3 (permalink)
Old 03-06-2002, 07:17 AM
STEVE1103 STEVE1103 is offline
STEVE1103 is starting off with a positive reputation.
flathead question
My Dads 53 Ford had the cross over, look liked the ones on a lot of 54-57 Fords had.
__________________
STEVE1103
  #4 (permalink)
Old 03-14-2002, 07:10 PM
DightonFord DightonFord is offline
DightonFord is starting off with a positive reputation.
flathead question
I have a '46 1/2 ton with a '49 engine. It has the single outlets on each manifold and uses a conventional crossover pipe. I have to earlier engines (early-mid forties and the manifolds are a different shape (bends). I have some excellent pictures of the installed if you want them. I will need some help from the "boss" to download them. Hope this helps...Joshua
  #5 (permalink)
Old 03-18-2002, 09:54 PM
jml jml is offline
jml is starting off with a positive reputation.
flathead question
__________________
JML---Go FORD!
http://www.48f-1.com
1948 F-1 Restored Stock
1966 Ford Thunderbird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
