Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-12-2002, 07:04 AM
Kurts50 Kurts50 is offline
Garage is empty, add now
Kurts50 is starting off with a positive reputation.
1950 flathead v8 wide vs. narrow pully engines?
I just purchased a 1950 flathead v8. I had 2 to chose from (not sure of the other year but my f5 dually is a 1950). I picked the 1950 engine as my engine has a cracked block. I paid $300 for it and supposely it runs good. He advertised the two engines as one having "narrow" pulleys and one having "wide" pulleys. The one I picked has the narrow pulleys. What's the difference? If my f5 has wide pulleys will everything interchange onto the new engine? Thanks!
__________________
Kurt Thomas
Durand, IL
  #2 (permalink)
Old 05-12-2002, 05:23 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Trucks ran the wide belt pulley while the narrow belts were found on cars. The engines are identical for all practical purposes, and with the 50 engine you should have hardened valve seats which is a plus. If you bought the engine complete (including fan, generator, etc.), you can run it as is. If all those goodies are absent, you could swap the bolt on belt accessories from your cracked engine since all flathead blocks are the same (48-53 US trucks).
Check to see if the fan lines up with your radiator shroud. As long as the engine runs with no cracks or other problems, I'd say you did good. - tim
  #3 (permalink)
Old 05-20-2002, 05:01 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
I had a 49 Ford car with a V-8 and it had wide pulleys. I noticed at that time that the 50s and up had the narrow pulleys on them.
__________________
ENCS(SS), (SW), USN RET (E-8)
Keweenaw Bay, MI
U.S. Navy (Submarine Service) 60-80
2010 Ford F-150 4WD Lariat Ext Cab
1999 Lincoln Town Car Ecec Series
1930 Model "A" Coupe
  #4 (permalink)
Old 05-22-2002, 03:17 PM
hamz52 hamz52 is offline
hamz52 is starting off with a positive reputation.
Hi
You might also want to check the distance between mounting
holes on the narrow belt water pumps. I tried to drop in a
motor with them once in my 52 and they didn't match up with stock
motor mounts. Barely missed so I had to change out the water
pumps to the wide belt for the truck. Good luck
Hamilton
  #5 (permalink)
Old 06-10-2002, 08:13 PM
MikeInNM MikeInNM is offline
MikeInNM is starting off with a positive reputation.
Tags
1950, belt, engine, f1, fan, flathead, ford, lincoln, pulley, pully, pump, size, timing, v8, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
