Aluminum Block Flathead V8 - Ford Truck Enthusiasts Forums
Old 06-09-2002, 12:18 PM
MikeInNM MikeInNM is offline
MikeInNM is starting off with a positive reputation.
Can anyone shed any light on the aluminum block Flathead V8 engines that were made in the 40's? Supposedly only 10 were made. Any information or direction for knowledge would be appreciated as well as the possible value of one that is in good condition and running well.
thanks......
Old 06-10-2002, 01:53 PM
STEVE1103 STEVE1103 is offline
STEVE1103 is gaining momentum as a positive member of FTE.
Rumor going around that someone is makeing some new flathead blocks and some will be aluminum, would be nice if it is true. Where in NM are you located?
Old 06-10-2002, 09:13 PM
I am in Eastern New Mexico Clovis/Portales area. This engine has been in this truck for ages and is in a private collection so it wouldn't be a recent thing. It's the real "McCoy" and I have heard that it is possible that only 4 of these are left in existence of the original 10.
Old 07-01-2002, 08:20 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Flathead v8 valve guides Skalywag 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-03-2015 10:53 AM
1951 F1 Flathead V8 Aluminum Radiator 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 08-29-2013 05:24 PM
T-5 to Flathead adapter info? OilLeaks 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 12-28-2011 01:00 AM
Replacement radiators for flathead v8 Gord4048 1947 and Older Ford Trucks 3 02-13-2009 08:49 AM
Flathead V-8 parts identification 51dueller Flathead V8 & Flathead 6 6 03-21-2004 11:01 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
aluminium, aluminum, alumiunm, alunimum, block, blocks, engine, flat, flathead, ford, head, model, motor, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
