Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-22-2008, 08:27 AM
n2umr is starting off with a positive reputation.
LT Tires
Has anyone put LT tires, load range "E" on their 07 or 08 expy? I was looking at doing this but wondered how much it would change the ride of the vehicle.
Mark
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-22-2008, 09:57 AM
montecarlo31 is starting off with a positive reputation.
It will ride stiffer even w/ the proper pressure (not the PSI on the Door). It will handle better as it has less tire roll. The truck will also be slower as there is more rotating mass to move. P metric tires are much lighter then a LT. You don't need "E"s on a expedition, you'll be fine with some "C" or "D" ratings.
  #3 (permalink)
Old 05-23-2008, 07:32 AM
chuck s is starting off with a positive reputation.
Not sure what LT tires would do of any benefit. GAWRs won't change as they're well below tire ratings so are probably tied to suspension and frame components.
LT tires should contribute to a more truck ride, though, if that's what you're after.
-- Chuck
  #4 (permalink)
Old 05-30-2008, 01:04 PM
nebmike's Avatar
nebmike is starting off with a positive reputation.
This is just me, but if you have a specific tire you're looking at that you can only get in an E load rating for the size you need, I'd just get it. I've put E's on several vehicles that didnt "need" 'em (2 Grand Cherokee's, a Bronco and a Blazer) and to be perfectly honest, I could never tell a hoot of difference in the ride. Maybe a smidge more noticeable feel over road cracks, but certainly nothing that equates to the comments most people make about how rough it'll make the ride.
I mean, if you put 80psi in 'em you'll get a rough ride -- but if you stay within the load limits of everything else (GVWR, GAWR, etc.) you'll never need that much pressure.
I know two guys who have E rated Goodyear ATS's on their Expy's and I've ridden in both and they ride exactly the same as mine.
And just because I know somebody will ask, I'll give you one example of why you might go with an E tire on a truck that doesnt "need" it. I had an '01 Grand Cherokee with a 2" lift and 17" wheels... I wanted a more agressive off-road tire because I did a LOT of 4-wheelin in the Colorado mountains. Well, the only tire I could find (other than no-name generic brands) with a tread design I liked, and that made a 17" tire that would fit inside my wheel wells and clear while turning and under extreme articulation was a Cooper Discoverer STT -- and in the paticular size I needed they only made an E.
__________________
Mike
'07 Expedition EL 4x4 (its really more of a 4x3... see the gallery ) Eddie Bauer, Tow Pkg
(Recovering V-10 Excursion owner)
'04 Super Duty Lariat 6.0L 4x4, Airbags, Edge w/ Attitude
2007 Laredo 315RL 5'er, 35', 11.5k loaded, Onan 4k onboard
Pictures in Gallery
(Check classifieds for used tuners and gears)
  #5 (permalink)
Old 05-30-2008, 02:40 PM
rockstate45 is starting off with a positive reputation.
I got an 07 Tundra with BFG AT T/A KOs. Stock tire is 275/65/18. The new one is 285/65/18. It's definitely a rougher ride - because I run 50/50 psi in there as opposed to some bull***** like 30/33 on the door. When I run them down at about 40 there's little difference. I like the stiff ride of 50/50 plus I can get max tire life out of them there.
If you want to sacrifice a little wear you can run them at door pressures but just buy a depth gauge and check it. Buddy of mine that works at Firestone said within 1.5 mm from center to outside is normal wear.
Heres a pic of 'em all muddied up:
Vs with the old Bridgesones.
The thing looked like a work truck before.
-rockstate
__________________
2007 Toyota Tundra 5.7, 4x4
Rhino Liner, Borla Exhaust,
Ranch Hand Grille Guard,
BFG AT KO 285/65/r18
1998 Ford Expedition 5.4, 4x4
  #6 (permalink)
Old 05-30-2008, 03:48 PM
fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.
I put E-rated Pirelli Scorpion ATR's on my 2000 Expy recently, and I love them so far.
Feels more solid on the road - less roll.
Now, max inflation on these is 80psi, and door sticker pressure is 35. So I split the diff and run 50psi when unloaded. Keeping an eye on wear, but it's only been 1,000 miles so far.
Zero loss of gas mileage that I can detect. Actually quieter than the old tires. Have worked well on swamped forest roads.
  #7 (permalink)
Old 05-31-2008, 08:23 AM
hookd's Avatar
hookd is starting off with a positive reputation.
I put cooper discoverer ATR's on every one of my personal trucks and our fleet at work. we put about 15000 miles a year on each of our work trucks driving highway and gravel and I think these are the best tires you could get for the money. I only get E rated because we get into allot of rough gravel and were getting more flats with the lighter tires and with the ATR's the wife can't even tell a difference in road noise. we wind up replacing them about every 2 - 2.5 years. The only other tires I would consider are yokoham geolanders I hear allot of good things about these from the guys that run the oilfields up north.
Good Luck
__________________
HOOK
07 Expedition EL 4x4 XLT(the wife won't allow mods)
  #8 (permalink)
Old 06-02-2008, 08:43 AM
Thanks for the discussion, I actually was looking at the Cooper ATR's for my Expy to replace the Continentals. I was thinking about the Cooper H/T's because I had a set of those before and most of my driving (90%) is highway.
Mark
  #9 (permalink)
Old 06-02-2008, 11:33 AM
berry1234 is starting off with a positive reputation.
Of all the trucks/Expys I have had(5), when I put on LT tires the ride suffered noticeably, but the tire seemed to last longer. Just my experience.
__________________
2008 Expedition Eddie Bauer 4x2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
