Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-20-1999, 09:10 PM
fugates fugates is offline
Garage is empty, add now
fugates is starting off with a positive reputation.
MERC. FLATHEAD
I have just acquired a (49-53)flathead marine engine that I would like to install into my 51 F1.
I am wondering if there is a lot of differences between the normal 239 and the marine engine
  #2 (permalink)
Old 07-05-1999, 10:05 PM
Steve Hansen
Guest
Posts: n/a
MERC. FLATHEAD
I'm going to guess on some answers for you, based on what I learned on my boat. It is a 1978 Lund with a 302 V-8 The basic engine at that time was a car eng, with marine attachments. The starter, Alt, Carb are all desighned to resist rust and corroseion, and to not make fuel fumes and sparks. The Distubetor is different, but the internal eng is the same. Now I am guessing that an older eng would have LESS different parts than mine, But it gives you something to start with. Now if it is a true Merc eng, that opens up the possability of really hot-roding. Any Questions e-mail me..
  #3 (permalink)
Old 07-06-1999, 04:44 PM
Sam Fugate
Guest
Posts: n/a
MERC. FLATHEAD
Yes It is really A Merc FLathead (Cast on the heads), Since I made the first post Ihave removed the hedas and found that It has a 4" stroke (Pure Merc). Did you say Hot Rod? This Motor is going into my 51 EFFIE!
  #4 (permalink)
Old 08-09-1999, 07:58 PM
fordman_1 fordman_1 is offline
fordman_1 is starting off with a positive reputation.
MERC. FLATHEAD
There is a little differnces from ford and mercury engines.The merc was a little thicker in the block around the valve seat and the cyl and they didn't crack the block as bad when you got them hot. and they had 10 more horsepower than ford.They used diff.cam shaft and head. and marine had 10 to 15 more hp than car engines.In the late 60, I had woods boat with a 51 merc engines. YOU CAN PUT IT IN WITH NO PROBLEMS.
  #5 (permalink)
Old 08-26-2001, 09:06 AM
Wired Wired is offline
Wired is starting off with a positive reputation.
MERC. FLATHEAD
I got both Ford and Merc engines and I only can see a difference in the crank and was told by a reputable machine shop that if the block of the Merc is cracked to save the crank as it is a 1/4 of an inch longer throw and believe me they still crack in all the same places ( 1/4 inche throw accounts for the 10 hp increase and a cam and head change would increase it even more ). I just put a set of Edelbrock heads on one and increased the horses up 25 % ( compression ratio went from 6 1/2to 1 to a whopping 8 to 1 ) .
So as far as using this in your truck it will work and if it is fresher then you will notice a big change but if it isn't then it will be the same . Just remember that the Ford is a work truck and the Merc is just the same but dressed up .
  #6 (permalink)
Old 07-22-2002, 07:08 AM
mercuryblues mercuryblues is offline
mercuryblues is starting off with a positive reputation.
MERC. FLATHEAD
If it has a 4" stroke its a 255cid most Mercs cars and trucks meteors and monarchs used this engine.
__________________
1959 M100 383/700r4
1970 T-Bird 429/360hp
1955 Ford Ranch Wagon
  #7 (permalink)
Old 07-24-2002, 12:15 AM
soso soso is offline
soso is starting off with a positive reputation.
MERC. FLATHEAD
Tags
flathead, ford, merc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
