transmissions
Old 08-07-2002, 11:17 PM
mtflat's Avatar
mtflat
mtflat is online now
transmissions
Old 08-29-2002, 09:42 PM
51dueller's Avatar
51dueller
51dueller is offline
transmissions
What transmissions will fit my '51 Ford 239 flathead. Would a later transmission fit? Were those F-8 5 speeds any good. If possible would you be able to list all the transmissions that would fit.
Thanks
Nathan
Old 08-29-2002, 09:52 PM
tcw's Avatar
tcw
tcw is offline
transmissions
i believe the truck would have come with a 3 speed trans.a four speed would have been an option. i think that you can get an adapter to use some newer transmissions. try offenhouser. tim
Old 08-30-2002, 12:07 AM
mtflat's Avatar
mtflat
transmissions
Nathan, according to the shop manual the F8 had 2 tranny options - a regular 5 spd and a 5 spd od. 1st, 2nd and Reverse were spur gears. 3rd, 4th and 5th were helical gears.
The gear ratios only gave 2 more granny gears. Third gear ratio of 2.40:1 was similar to first gear in the F1 3 spd. So you wouldn't gain anything if you could even bolt it up. I haven't seen one, but I wonder if the tranny for the 8EQ matches the 8RT bellhousing??
I think you might do better to look for a T5 or an OD from a mid 80's pickup.
Old 08-30-2002, 01:12 PM
51dueller's Avatar
51dueller
transmissions
My 51 ford truck has the shifter on the floor, so I think it is a 4 spd. But it is all so a double clutch which I would like to get rid of. On the flat-o website it says the adaptor may work with later engines. Did the y-block still have the same transmission housing?
Nathan
Old 08-30-2002, 10:34 PM
jeffh's Avatar
jeffh
jeffh is offline
transmissions
Might want to check out this site -
http://www.geocities.com/zeener96/t-5tranny.htm
bradphx
67
01-10-2024 06:12 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Oklahoma Chapter
04-11-2003 10:33 PM
walterdanek
16
02-16-2001 07:56 PM
Quick Reply: transmissions
