Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-07-2002, 11:17 PM
mtflat mtflat is offline
Garage is empty, add now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
transmissions
  #2 (permalink)
Old 08-29-2002, 09:42 PM
51dueller's Avatar
51dueller 51dueller is offline
2003 Ford Explorer Sport Trac
51dueller is gaining momentum as a positive member of FTE.51dueller is gaining momentum as a positive member of FTE.
transmissions
What transmissions will fit my '51 Ford 239 flathead. Would a later transmission fit? Were those F-8 5 speeds any good. If possible would you be able to list all the transmissions that would fit.
Thanks
Nathan
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
  #3 (permalink)
Old 08-29-2002, 09:52 PM
tcw tcw is offline
tcw is starting off with a positive reputation.
transmissions
i believe the truck would have come with a 3 speed trans.a four speed would have been an option. i think that you can get an adapter to use some newer transmissions. try offenhouser. tim
  #4 (permalink)
Old 08-30-2002, 12:07 AM
transmissions
Nathan, according to the shop manual the F8 had 2 tranny options - a regular 5 spd and a 5 spd od. 1st, 2nd and Reverse were spur gears. 3rd, 4th and 5th were helical gears.
The gear ratios only gave 2 more granny gears. Third gear ratio of 2.40:1 was similar to first gear in the F1 3 spd. So you wouldn't gain anything if you could even bolt it up. I haven't seen one, but I wonder if the tranny for the 8EQ matches the 8RT bellhousing??
I think you might do better to look for a T5 or an OD from a mid 80's pickup.
  #5 (permalink)
Old 08-30-2002, 01:12 PM
51dueller's Avatar
transmissions
My 51 ford truck has the shifter on the floor, so I think it is a 4 spd. But it is all so a double clutch which I would like to get rid of. On the flat-o website it says the adaptor may work with later engines. Did the y-block still have the same transmission housing?
Nathan
__________________
Nathan
  #6 (permalink)
Old 08-30-2002, 10:34 PM
jeffh's Avatar
jeffh jeffh is offline
jeffh is starting off with a positive reputation.
transmissions
Might want to check out this site -
http://www.geocities.com/zeener96/t-5tranny.htm
__________________
1950 F3 -- "Big Tank"
Missouri chapter member
Tags
flathead, spd, t5, v8, zeener96
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
