Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-07-2002, 10:47 PM
jpb222 jpb222 is offline
Garage is empty, add now
jpb222 is starting off with a positive reputation.
merc engine?
I just paid $100 for a running flathead for my 49' f-1.
It has EAC cast into the head which means it is a mercury right?
Did ford put 255's in the bigger trucks fom the factory?
It is out of a 1952 f-4.
I didn't check the stroke yet to verify if it is 4".
thanks,
John
76' f-100
49' f-1
52ish f-1
__________________
two restored 1979's a 350 4x4 and a low mile 150 2wd
three 66-77 EB's, one restoration, and 2 rock buggies
three 48-52 f-1 pickups, one sleeper, one 4x4 DD and one restoration project
  #2 (permalink)
Old 08-07-2002, 11:17 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
merc engine?
[updated:LAST EDITED ON 08-Aug-02 AT 00:19 AM (EST)]EAC on the heads means it has 52/3 merc heads. Only way to verify you have a merc flatty is to pull a head and measure the stroke.
'52 F4's only had the 239 flathead as the V8 option. Not until you got to the BIG trucks did you have a different engine - then they were 279 (F7) and 317 (F8) OHV motors.
Swapping a merc motor into a farm truck for extra torque was fairly common. I picked one up from a 46 Ton 'n a half.
Check the passenger rear corner of the intake flat for an alhpa-numeric string of symbols that will tell you what year it was assembled. If it has been rebuilt, then all bets are off.
Keeping my fingers crossed for you.....
Tim
  #3 (permalink)
Old 08-13-2002, 09:07 PM
merc engine?
I took the heads off tonight.
I am very happy to say that it does have a 4" stroke!
It is standard bore!
Everything looks great inside!
And there are no cracks between the cylinders!!!!!!!!!!!
I may even give my friend an extra $50 for giving me such a great engine for such a great price.
Now on to re-building it.
Also is ther any benifit in putting 8ba heads on it (ie. higher compression since the stroke is less on a 239) I have a set of off my other junk motor. Also if anyone wants the crankshaft out of the junk motor they can have it for very cheap since I don't need it now.
Thanks,
John
__________________
  #4 (permalink)
Old 08-26-2002, 07:17 PM
Greg Watson Greg Watson is offline
Greg Watson is starting off with a positive reputation.
Post merc engine?
You might want to find a set of 8RT heads if it is a Canadian built Merc motor. They are the standard heads for Canadian Merc truck motors according to my 1950 Mercury truck owners manual.
  #5 (permalink)
Old 09-04-2002, 12:23 PM
54_5star 54_5star is offline
54_5star is starting off with a positive reputation.
merc engine?
[updated:LAST EDITED ON 04-Sep-02 AT 01:24 PM (EST)]I'm not sure if the 8BA heads will give a compression increase over the EAC heads. The '52/'53 car heads ( don't know the casting code ) would bump it up a little.
  #6 (permalink)
Old 09-04-2002, 03:08 PM
merc engine?
Tags
engins, merc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
