Flathead engine ID help - Ford Truck Enthusiasts Forums
Old 08-02-2001, 01:21 PM
whomrig whomrig is offline
whomrig is gaining momentum as a positive member of FTE.
Old 09-27-2002, 01:27 PM
Bigran Bigran is offline
Bigran is starting off with a positive reputation.
Post Flathead engine ID help
I recently bought a 1944 Ford 2N tractor. It has a conversion to a 6 cylinder engine. Numbers on the side of the motor are - K18311. Does that mean anything to anyone? I'm trying to find out the year and anything else I can about the engine so I can get working on it. Thank you for your help.
Old 09-27-2002, 05:48 PM
54_5star 54_5star is offline
54_5star is starting off with a positive reputation.
It should be a 226 flathead. There are early and late ones differing in the location of the distributor. Is the dist. on the right front ( 41-47? G series ) or on the left side ( 471/2-51 H series )?
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Exhaust (cat) 1987 - 1996 F150 & Larger F-Series Trucks 7 08-22-2012 11:39 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1944, casting, engine, engineswaps, flat, flathead, flatheads, ford, head, id, identification, ids, information, motors, s, tractor, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
