Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 06-03-2002, 09:13 PM
Blue42 is starting off with a positive reputation.
Flathead 6 cylinders
I have a 42 1-Ton with original 6cyl G-series. Also have an H-series I ran in it for a number of years. Many thanks for the Flathead pages. If you need more pic's of either series, send me a note. Both engines are out and on stands while I'm restoring.
  #17 (permalink)
Old 06-20-2002, 10:29 AM
jml jml is offline
jml is starting off with a positive reputation.
Mercury's......all in the Family....:-)
__________________
JML---Go FORD!
http://www.48f-1.com
1948 F-1 Restored Stock
1966 Ford Thunderbird
  #18 (permalink)
Old 07-02-2002, 09:24 AM
soso is starting off with a positive reputation.
if you need a exploded view let me know ,I can scan one for you
soso@ntl.sympatico.ca
  #19 (permalink)
Old 08-21-2002, 09:36 PM
caseman is starting off with a positive reputation.
Just a point of interest, a lot of old Gleaner combines were powered by flathead six cylinder Fords. Pretty much the same engine, but had a different cover on the front for installation of a gear driven governor, and a large pulley drive bolted on the rear. There are still a number of these sitting around in combine boneyards, if you are looking for one.
  #20 (permalink)
Old 09-28-2002, 04:55 PM
jimsof is starting off with a positive reputation.
I know these have been up here for awhile but I will give my two cents worth anyhow. I have a 51 F-6 with a M series "big 6". I also had a 49 with an H series 6 which recently blew on. I replaced it with a 53' v-8. The only problem I ran into was the flywheels are not interchangeable. I would say the big six has more torque than the v-8. Glad to finally see something on the flathead sixes on the net..Jim
  #21 (permalink)
Old 09-30-2002, 01:15 AM
1948FORD is starting off with a positive reputation.
  #22 (permalink)
Old 02-07-2005, 08:11 AM
M6ride is starting off with a positive reputation.
Smile still looking for F6 BIG 6 ("M") rebuildable engine
Please don't send it to the scrap yard; I need a good solid M series engine.
Just, please email me in case you know where one is. I need one for my shoe box.
THANKS,
john
  #23 (permalink)
Old 03-10-2005, 02:33 PM
51ford fan's Avatar
51ford fan is starting off with a positive reputation.
Quote:
Where are these yards located ??? I would also like to find one of those "M" Flatheads.
  #24 (permalink)
Old 12-07-2005, 12:34 AM
ron_29_1973 is starting off with a positive reputation.
i have a 52 ford f6 im working on with the flathead 6 4speed 2speed rearend does anyone know what other kind of truck 4speed will work i have one from a 63 f600 would that work i want to shift the gears without stoping lol
  #25 (permalink)
Old 12-07-2005, 09:11 AM
51ford fan's Avatar
Check out this 254 6 cylinder enginehttp://www.powertechengines.com/Ford254WaterPump.html
  #26 (permalink)
Old 12-07-2005, 10:16 PM
rswhitmore is starting off with a positive reputation.
The 49-51 f6 was available with a 254 flathead six. It was rated 112HP and 217LB.FT of torque(in 51). Thats not too shabby! I have a good running 1951 254CID flathead six. I am trying to decide wether to put it into one of my old trucks, or sell it to someone looking to build-up a really strong flathead six. The 254 6's are not very plentiful in solid running condition.
  #27 (permalink)
Old 02-10-2006, 08:26 PM
F6Guy is starting off with a positive reputation.
I beleive there are two diffrent belhousings you could get on a flathead in 52. and the t-98 warners came in either configuration. If still no dice cornhusker sells adapters that retain the centershaft throwout bearing but you can put any modern trans including an overdrive. or use a fork style throwout bearing. Just for petes sake dont stuff an auto in it.
  #28 (permalink)
Old 02-10-2006, 10:10 PM
oops I thougt I was on the V8 thread, I don't Know to much "bout them six bangers cept that they put em in all the way up to the 254 in the f-6. and that them 254 were some mules.
  #29 (permalink)
Old 10-08-2007, 11:22 PM
Jeeptrix is starting off with a positive reputation.
Count me in and lets get this forum up and running on all six cylinders. I have a 51 F6 with it's stock 254 M. It's looking good so far. It's not a bad motor right outa the box but I've seen plenty of options already that will make it a great motor. Dual carbs, header, dual exhaust. A friend of mine has seen a fake downdraft carb that hides a throttle body fuel injection system so I don't want to jump to dual carb just yet. I've heard you can put the 226 head on the 254 engine and increase the compression substantially. I just had my old head taken down 23 thou to take the warp out so that should increase it a little.
I was going nuts the other day trying to find a solution to the old canister oil filter. I'd heard of people stuffing rolls of toilet paper in them and all kinds of conversions but none I'd call simple. So I decided to phone my local auto parts store. They suggested I call the local oil change guy and I was really losing heart. I decided - what do I have to lose? The oil change guy references it in his system in 10 seconds flat. Gives me a part number for the auto parts guy. I phone the auto parts guy back who has the correct cartridge in his hands in - you guessed it - 10 seconds flat.
I LOVE THIS TRUCK! So far everything I've needed to get it running has been off the shelf. The trick is in the sharing of information. Thank heaven for forums like this one. Nice site JML. That's a real purty 226 you got there, now that you have the color right! ;-) Can I have the head when you're done with it?
  #30 (permalink)
Old 10-10-2007, 09:06 AM
I spoke too soon. Now I'm up the creek without an exhaust manifold. I even had a hot shot welder lined up to repair the one I've got but it's not just cracked. It's in bits and pieces. Can anyone offer a lead to a good stock manifold or a header? I've learned that a header can be made from combing the old manifolds from truck and car. I do like the idea of retaining the carb heating properties of the stock manifold as well as the reduced engine noise through cast as opposed to tube headers.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
